Show your exhaust setup.
Old Feb 13, 2008 | 10:26 AM
Black Hawk's Avatar
Im getting ready to do true dual exhaust with a x pipe and magnaflow flow through mufflersin 2.25 piping but im debating on whether on to dump it or run in out the back at 45s to the rear bumper.
Old Feb 17, 2008 | 02:50 PM
Black Hawk's Avatar
Does anyone have some pics of a true dual setup with an x pipe that they could post up?
Old Feb 17, 2008 | 03:10 PM
This is not mine, but every time I see it I
Old Feb 17, 2008 | 03:26 PM
built54's Avatar
Here is mine. 2.5" pipe. bassani mufflers, x pipe, dumped with tips
Old Feb 17, 2008 | 03:52 PM
attworth's Avatar
yeah.... it needs to be fixed...
Old Feb 18, 2008 | 12:06 AM
Black Hawk's Avatar
Built thats the setup Ive been looking at, just pondering on whether to dump it or run out the back corners. What are advantages to having it dumped?
Old Feb 18, 2008 | 05:37 AM
Kevin24's Avatar
It will be considerably louder if you dump it depending on where you end it at. It will also probably drone a little at certain RPM's.
here is mine.......
Old Feb 18, 2008 | 08:31 AM
built54's Avatar
No advantages, just dont see the tips, which is what I like. It is so quiet in the cab. there is no drone, hardly any noise at all. at idle, it almost sounds stock from the inside.
Old Mar 12, 2008 | 01:59 AM
7lug's Avatar
what system is that? Its nice except for the muffler seems a bit too small for my tastes...I'm looking for deep and not too loud
Old Mar 12, 2008 | 02:02 AM
7lug's Avatar
Built - are those Bassanis straight through or chambered. Still trying to decide between 2.25 Magnaflow DI/DO straight throughs or 2.5 dual flowmasters 40 series - both with x pipe and stock cats - I want power for towing more than just peak HP -
Old Mar 12, 2008 | 02:05 AM
joshmac4.6's Avatar
Built, off topic, but i noticed the aluminum driveshaft, where did you get it?
Old Mar 16, 2008 | 10:34 PM
xmotoxgeorge's Avatar
Built, any benifit from running the exaust all the way out the back and over the axle from your setup? In comparison to dumping it before the axle?
thanks George
Old Mar 16, 2008 | 10:40 PM
shifty_85's Avatar
My 97 F-150 4.6L came with the aluminum drive shaft. i thought almost all F-150s did....97 and up...Didnt they?
Old Mar 17, 2008 | 03:05 AM
Tornadom's Avatar
I can't upload pictures here at work, but I have the Magnaflow SI/DO that exits in front of the right rear tire.
It sounds good, was simple to install and is easy to care for.
Old Mar 17, 2008 | 03:28 PM
dumchris's Avatar
Sorry pics aren't that great an truck is filthy, at work, dirt, gravel, and muddy roads. Don't know when i'll be going home so she's gonna stay dirty for now.....
