AF1 or Tune?
Old Jan 29, 2008 | 12:21 AM
MexicoDan's Avatar
AF1 or Tune?
Just got my Magnaflow exhaust, and itching for mod number 2. I have to do these all seperate since I'm incapable of saving money. Should I go with the AF1 intake first (the 3" which doesn't require a tune and I have an 03) so I can send in my info when I order the tunes or get the tune first? Pro's Con's?
Old Jan 29, 2008 | 05:13 AM
Tornadom's Avatar
Either one should make you smile... the tune is nice becuse it also firms up your shifts, and allows for a lot more than a simple breathing mod. The intake is nice in that it is pretty under your hood, and makes that addicting roar under heavy throttle input... plus it's cheaper.
If you have the money for either, get the intake and save for the tune. I think it takes a while to get Troyer tunes, I am not sure how it works for payment though.
Old Jan 30, 2008 | 08:10 AM
MexicoDan's Avatar
That makes sense. I can get the CAI pretty soon then wait for the tunes. I don't start hauling my boat until June so I'd rather have some immediate benefits for my commute.
Old Jan 30, 2008 | 08:45 AM
Tornadom's Avatar
Yeah, that sounds reasonable.
I am in the spot where I am not sure if I would rather re-gear, or get an Intake, longtubes, exhaust, e-fan, and a tune. These 3.55 gears and 35's are not playing well together.
Old Feb 1, 2008 | 06:09 PM
FX4&EXCURSION's Avatar
The FIRST thing I would do is re-gear. 4:10's would be one of my considerations depending on what your truck is used for.
Old Feb 1, 2008 | 07:04 PM
ModBargains's Avatar
I would go with an intake before you do the tuner, have you looked into the S&B filters at all?
Old Feb 1, 2008 | 07:21 PM
MmmBuckles's Avatar
tune is going to give you the most gain.
Old Feb 2, 2008 | 10:10 AM
MexicoDan's Avatar
I know the tune will give me the most gain, I'm just thinking that if I get the CAI first, then I can send the exhaust and intake info in along with my order for the tunes.
As far as the SB filter, just looked it over. Honestly, I wouldn't be able to tell the difference between any CAI system. I'm just going with the advice of the masters of the forum. I'm leaning AF1 since I'll probly get my tunes from them also. But I'm also a mechanical idiot, so the installation scares me.
Old Feb 2, 2008 | 12:19 PM
MmmBuckles's Avatar
AF1 is probably the easiest thing i have ever installed on my truck. its like 2 bolts and a couple plugs
Old Feb 2, 2008 | 12:28 PM
I haven't seen the AF1 in person, but from what I can tell, theres just more to the S&B and it seems like they actually put some engineering and design time into it. AF1 is just an open filter right? S&B has either a heat shield or airbox depending on the model to keep some of the engine heat away.
Old Feb 2, 2008 | 12:41 PM
openclasspro#11's Avatar
and why is this-btw- af1 outperforms sb intakes-seen it on the dyno first hand
Old Feb 2, 2008 | 01:05 PM
I would do intake first to maximize the performance of the tuner. From what i've always done with trucks is do the hardware first, then tune it all up.
I dont see how the AF1 can really outperform S&B when AF1 uses the S&B filters. And as far as dynos go, you can skew numbers very easily on a dyno... I like to see dyno charts for comparison, but what was the difference between AF1 and S&B? 1-2 hp? You could dyno the same truck 3 times and get 3 different hp readings. Also, was it the same truck that had both intakes, on the same dyno, the same day?
Old Feb 2, 2008 | 03:08 PM
esf's Avatar
esf
Why not just order the tunes and you can send in the info for the exhaust and intake with the order. Then by the time two or 3 months rolls around and you get your tunes you could have saved up and have gotten the intake already. If it's the XcalIII you can just run the canned tunes in the meantime.
Old Feb 2, 2008 | 03:20 PM
shaunakadub's Avatar
Would work if he is in fact ordering his tunes from Troyer with the ridiculous wait time.
VMP tuning takes a week
Old Feb 2, 2008 | 04:45 PM
esf's Avatar
esf
I just assumed.
