stripped header bolt!
Ok, well i stripped one of the header bolts to the head..... the bolt does not get tight.... I knoticed a slight exaust leak only when i put my foot into it... its only noticable in the cab... its on the drivers side.... I am a little concerned.. Does any one have a solution, and should I be really concerned with this problem? thanks -George.
no I have not tried that yet..... I just guessed that since the bolt is steal and the head is alumium that is was the head..... I guess i am going to have to buy a tap set ... nvr done it before ...... and I really dont want to take the headers off again lol..... if i just run the truck the way it is will i cause any problems?
Thanks for your help guys! .... yeah the noise is starting to get irritating.... One more question? when and if I have to do the tap should i replace the gasket or since its only a week old will I be ok? -Thank George
go to napa and buy the factory manifold gaskets so you can reuse them, they will also never blow out.
Built54 , I have a quick question i picked up a tap. Just wanted to know if i pick up the right size its a 8mm x 1.25 metric.... it looks the same size as the original bolts.... Just wanted to know if you knew the head size and what tap I should use.... Also would it be better if i just used a heli coil? Thanks George
Originally Posted by built54
Well now i'm not sure on the size, try running it in the threads of a good header bolt hole. you may need a heli coil, im not sure on the extent of the damage.
sometimes you have to bite the bullet and have a do over... yes if that leak becomes big enough, and it will... it can cause a burnt valve if you suck up some good cold air back in it on decel., it can cause a lean condition, it can cause a rich condition after the computer starts seeing it.
Those header bolts are small and easy to strip. Depending on which cylinder , you may be able to use the stock stud. The stud threads further into the head and you may be able to achieve torque on the stud , then the nut. It might be allot better then what you have now - but it depends on which one is stripped , you may not be able to use a stocker if theres not enough clearance.
Off course re-tapping is allot better..
Sorry to resurrect this thread....
I just had the same thing happen tightening one of my header bolts.....
It seems to be stripped inside the head, I can't find the stock bolts I removed 3 years ago when I installed the headers.
Any ideas, I haven't looked yet but will be looking at Heli Coils....Will the header need to be pulled to install the coil....I have had a lot of trouble with these bolts and the steel is crap on them. I replaced a few but this last one I overtightened
Any ideas??
Thanks!
Any ideas??
Thanks!
Thanks, I have 2V heads........any ideas on how much longer it needs to be? or how far/deep the threads go into the head? I think my existing bolts are about 1" - 1.25" long
Should I look for a stud and separate bolt?
Would Napa carry a bolt like I need? I don't think O'Reillys will have it.
Thanks!
Thanks!
