Pipe Diameter... 2.5 vs 3.0
Old Jan 6, 2008 | 01:32 AM
zhoova928's Avatar
im planning on my local shop putting on a custom mid pipe with 2 high flow magnaflow cats and dual dynomax bullets.
should i get a 2.5 or a 3.0 inch pipe??
what are the pros and cons of each?
thanks
Old Jan 6, 2008 | 04:27 AM
roushstage2's Avatar
A general rule is that you can increase factory size by 1/4"-1/2" to gain/not lose any power. In your case with the EDGE, I'd go with 1/2" bigger for maximum potential, so to speak.
http://www.magnaflow.com/07techtips/faq/question10.asp
Old Jan 6, 2008 | 05:59 AM
Kevin24's Avatar
I would go either 2 1/4 or 2 1/2. Stay away from 3 inch on your truck!!!
Edit... I see in your other thread you don't want to sacrifice sound with your new system. Since you are doing a 2 1/2 mid pipe i would go with 2 1/2 all the way back. The 2 1/4 would prob be a little more raspy and pop more than the 2 1/2 would. Some say to go no more than 2 1/4 on a true duel system but i just don't see the extra 1/4 inch hurting much for power. I hope your putting an X-Pipe in there????
Also built54 has always run 2 1/2 true duels i think and had no power loss.
