i need help with Roush dual (off Road)
Old Dec 10, 2007 | 03:38 PM
Speedy8's Avatar
This kit doesn't require to remove the cat right?
And could someone check to see if it would be legal in NC(im sure it is) cause i dont know where to check.
Old Dec 10, 2007 | 05:32 PM
rangerdogy's Avatar
No, it does not require removing the cat. If you look under your truck, there will be a straight pipe coming out of your cat with a connection to a pipe leading to your muffler. It hooks up right there.
Not a lawyer, but I would think it's legal in N.C. I've heard MANY louder cars (although most of them sound bad).
Old Dec 10, 2007 | 07:25 PM
cr500f150's Avatar
I think Mbrp is a little pricey, has anyone rebent the pipes from roush i like to see what it looks like after they did it.
12-07-2007 09:49 AM
2005lariatky Depends on the trailer. If you have a enclosed trailer or travel trailer then it is going to cause a horrible drone under load. I am in the same boat. I want the Roush Off-Road but I want the tips to the side behind the rear tires. There must be someone out there that has changed this? Anyone?!
i was woundering what it ment when you said horrible drone under load?
