True Dual on 4.6l??
Old Nov 11, 2007 | 07:02 PM
HURRICANE_ZC's Avatar
True Dual on 4.6l??
Would i be able to go true dual on an 06 4.6L-V8?? And if i could, would i need to buy anything specific to make everything fit and sound good. I want to go true dual split rear exit but wasn't sure if i could or not. thanks
Old Nov 11, 2007 | 07:06 PM
shaunakadub's Avatar
I think the biggest factor is just to make sure you buy the right size pipe. If its to big you'll loose all of your back-pressure which is bad.
I'm sure someone will reply with some more info.
Old Nov 11, 2007 | 08:34 PM
turbinator's Avatar
been running a true dual on my 97 4.6 for years now with no problems at all. i had the stock y pipe cut off and put the true dual on with glasspacks and side exhaust. used 1.5" pipe and it pulls good. really can feel it come to life at the 2000 rpm range. i love it. it also has 295-70-16's on it and an edge programmer set for the second level along with a cold air kit. runs great at 173000 miles.
Old Nov 11, 2007 | 08:57 PM
phil6608's Avatar
Hi, did you mean to say 2&1/2 inch pipe?
Phil
Old Nov 13, 2007 | 12:27 PM
ws6_guyscrew's Avatar
as long as all the piping is 2.5", tip size wont affect back pressure but tailpiping needs to be 2.5
Old Nov 13, 2007 | 02:34 PM
MudTerrain's Avatar
*sighs*
Exhaust gas velocity, not backpressure.
I'd go with 2.25" pipes.
