which maggie cats???
Old Nov 6, 2007 | 06:24 PM
seidita84t's Avatar
Question which maggie cats???
no applications for an 06' 4.6 as far as high flows??? which number is going to work... i dont care if i dont pass emissions. but i dont want that godamn light to always be on... also, since the o2 sensors mount IN the factory cats, will i have to mount them after the maggies??? and if i do, will it set off the light?
Old Nov 6, 2007 | 08:02 PM
seidita84t's Avatar
i guess no one has any input?? would really be nice.
Old Nov 6, 2007 | 08:24 PM
MGDfan's Avatar
Hi.
Check out these: http://www.troyerperformance.com/cgi...atalogno=54306
You have a 2.5" exhaust so these should fit.
Mount the O2 in a bung, welded on the pipe behind the muffler.
Should be fine, but you won't really know until you try, as O2 placement can be tricky.
Good luck.
Old Nov 6, 2007 | 08:50 PM
seidita84t's Avatar
i plan on going true duals with an H-pipe, so i'm moving down to 2.25" piping, 2.5 is a little big for the 4.6, so i'm going to use the 2.25 cats...... so do you think it'll bee ok to use the 2.25 cats?
Old Nov 6, 2007 | 09:00 PM
MGDfan's Avatar
Sure. They have those as well. http://www.troyerperformance.com/cgi...atalogno=54305
BTW - I'd use an x-pipe myself: http://www.troyerperformance.com/cgi...atalogno=10790
Give 'em a call - it's always good to get their advice on this stuff.
Good luck!
Old Nov 6, 2007 | 11:02 PM
seidita84t's Avatar
i heard that the H-pipe will give better low end though? and since the 4.6 doesnt rev to high, do you think it will help at all?
Old Nov 6, 2007 | 11:12 PM
mSaLL150's Avatar
you do know that in california it is illegal to tamper with stock cats at all...that means:
a) no high flows
b) you must run all 4 factory cats, and if one defects it must be replaced with the same exact factory cat
c) no cutting or tampering with them
eh, legality, who cares...
Old Nov 6, 2007 | 11:20 PM
seidita84t's Avatar
Did you also know that in Cali, its illegal to replace a cat in a vehicle with less than 100,000 miles if the vehicle was produced in 01/96 or later?? and yes... legality, who cares, if they made 02 simulators for post cat sensors, and for my truck, so there wouldnt be a mil on... i'd run an off-road pipe... i have a "smog" guy, so i dont care about passing, i just care about the performance and not having a stupid light on all the time
Old Nov 6, 2007 | 11:32 PM
seidita84t's Avatar
HAH!... i know its not that important to you guys, but check out what i found??? think they'de work?? http://www.rpmoutlet.com/gmo2s.htm
Old Nov 7, 2007 | 12:32 AM
phil6608's Avatar
Just so you know. You can get the Magnaflow high flow cats on ebay for about 55 bucks each!
Phil
Old Nov 7, 2007 | 09:12 AM
openclasspro#11's Avatar
not-use the x-pipe-phil
