Cat & muffler questions
I just bought an 06 F-150 STX 4X2 w/ 4.6 engine. I have read about all of the posts about the different exhausts available for my truck but I still have some lingering questions.
Does my truck have 4 cats ?
If I decide to install true duals with the Flowmaster Super 44's do I just remove the cats all together (assuming there are ones located aft of the muffler)?
Thanks for helping a F-150 NooB !
Tom
Tom
I stopped by a muffler shop today and the guy there told me I don't want to put duals on with the 44's because it would not have any back pressure and would run and sound like crap.
He said to run the exhaust into a single muffler and out as duals if I want but he recommended I stay with the single in / single out.
I just got out from under my truck and I only see two cats. Each are after the flange and in front of the cross pipe after that there is just one HUGH long muffler.
the muffler man was right. I wanted true duals. I have a 98 f150 with the 4.6L but if you got true duals and took off from a dead stop. you would just be making alot of noise. You loose performance with true duals. Go with a single in dual out super 44, with 4 inch tips or 3 1/2. it will sound awesome. I have a cherry bomb pro with si/do with 4inch tips and it sounds really good. its not over loud but when i get on it you can hear me a quater mile away .
Originally Posted by openclasspro#11
this guy doesn't know jack -hit!-if you true dual go no larger than 2.25"-if you sigle in do it- go no larger than 2.5" out-phil
Any true duel system set up correctly should perform well
Originally Posted by Kevin24
X2
