discolored rims
Old Jun 9, 2007 | 11:39 PM
ckerpal's Avatar
discolored rims
Today I noticed that my rims were starting to turn brown or discolored. I have a 97 ford f-150 that i cut the muffler off. Right now it is coming out infront of the tire causing the rim to turn colors how hard is it to run the exhaust behing the tire?
Old Jun 10, 2007 | 02:49 AM
Veteran: Army
try washing the wheels once in a while it may help
seriously I have a side exit in front of the wheel and I have no issues with discoloratin, but i also have a muffler too
it is pretty simple to re route the exhaust, get a pre bent pipe from a muffelr shop or have them do it for you
Old Jun 10, 2007 | 04:57 PM
Octane36's Avatar
Ford issued a TSB on the '97s that had the exhaust exiting just in front of the right side rear tire. On trucks with aluminum wheels, the exhaust gases caused them to get discoloration. Washing the wheels wont really do any good.
It wouldnt be all that hard to plumb the exhaust to exit behind the rear tire. A muffler shop should be able to do it for you for less than $200.
Old Jun 10, 2007 | 05:19 PM
TNC's Avatar
TNC
Your initial comment is that rims are turning brown. Just the one at the exhaust or all? I never had an issue with my '97 for 11 years. My '04 has the Lightning exhaust in front of the tire, again, no issues. Maybe there's something going on , like too rich. Just suggestions......
Old Jun 11, 2007 | 01:35 AM
syoung_2000's Avatar
I know you're not trying to take a poll here, but I have a '97 with the same exhaust and no problems with the rims.
I also have my tires rotated every 5,000 or so miles. Even so, never noticed the slightest of problems.
Old Jun 11, 2007 | 09:23 AM
jhitti's Avatar
just keep rotating your tires until there all brown, then they all will match!
Old Jun 11, 2007 | 10:44 AM
Veteran: Army
he needs to give us more info and definantly post some pictures of what he is complaining about,
it could just be brake dust from lack of washing...
Old Jun 11, 2007 | 11:10 AM
Faster150's Avatar
it was usually the center caps that discolored.. i had side exit on my truck for damn near 10 years and i cleaned my wheels and never really got any discoloration. because i have good fuel burn.. if u gettin alotta carbon on them probably need to do a seafoam treatment the cats are likely not functioning 100%
Old Jun 13, 2007 | 07:31 PM
ckerpal's Avatar
Its just the one behing the exhaust never had any problems till i cut off the muffler.
