ordered a ebay intake
Old Mar 28, 2007 | 02:39 PM
jamrens's Avatar
it didnt come with instructions and i was wonderinf if anyone hag a generic set they could help me with thanks in advance
Old Mar 28, 2007 | 03:02 PM
MGDfan's Avatar
Hi - if it's for an 04+ truck, return it - you are playing with fire ...
EDIT - saw the link: - don't bother - suspect filter quality, aluminum pipe is not good intake material...
Old Mar 28, 2007 | 03:25 PM
Copperhead64's Avatar
Intake type? Engine size? year of vehicle? Shoe size? Mothers maiden name?
Help us out here man !
Old Mar 29, 2007 | 01:16 AM
jamrens's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...6968436&rd=1,1
97, 4.6
Old Mar 29, 2007 | 01:24 AM
angus242's Avatar
jamrens,
If you can wait until morning, I'll take pics of mine and can help you out.
1998 4.6
I'll check back when I get up. Otherwise, good luck.
Angus
Old Mar 29, 2007 | 08:58 AM
ameration's Avatar
Originally Posted by jamrens
That is who I ordered mine from. It will need slight modification to get the MAF to fit properly (I had to buy smaller bolts), but for the money you can't complain. I've had mine on for 8,000 miles with no problems.
Old Mar 29, 2007 | 10:56 AM
jamrens's Avatar
could you give me a run threw on the slight modifications,,, mine will be hear sat just want to get my self prepaired
Old Mar 29, 2007 | 11:09 AM
ameration's Avatar
You will need to either leave the plastic cover off or trim it to fit the hoses through (the TRITON 4.6L cover over the TB).
You will need to get four smaller bolts to fit them through the MAF holes to mount the airfilter on.
You will need to re-route the hoses for the vaccuum lines and IAC (make sure you cut them long so you can adjust once everythign is installed.
I think that is it.
Old Mar 29, 2007 | 11:30 AM
jamrens's Avatar
that almost sounds complicated
Old Mar 29, 2007 | 11:31 AM
jamrens's Avatar
that almost sounds complicated, maybe i might have to get you to get pics of all that
Old Mar 29, 2007 | 11:40 AM
ameration's Avatar
If you have any mechanical skills you will be able to figure out all that you will need to do.
