can a cai cause a drop in gas mileage
Old Jan 17, 2007 | 08:44 PM
94slowbra's Avatar
i put on a cold air kit and i think my gas mileage has gone down. the filter is used and a little dirty. before i go out and by a new k&n im wandering if i should put the ctock stuff back on. the filter on there now is a knock off k&n. thanks for the help
Old Jan 17, 2007 | 09:13 PM
chester8420's Avatar
CAI's do not increase gas mileage. They take in hot air from behind the radiator, which hurts horsepower. I really don't understand them. It might help your horsepower if you figure out a way to bring in some cold air. As for gas mileage, unless you jacked up your MAF sensor with oil, there should be no decrease in fuel mileage.
Old Jan 18, 2007 | 07:24 PM
Redneck911's Avatar
My CAI doesnt pull ait from the radiator. in fact, my filter is seperated from the radiator by a piece of steel.
Old Jan 18, 2007 | 09:33 PM
thetruck's Avatar
Mine doesn't pull hot air from behind the radiator. It pulls air from the fender well. It's surrounded by a heat shield.
My CAI has increased my gas mileage. I've calculated quite a few times. It might be small but the increase is there. Numbers don't lie.
Old Jan 21, 2007 | 08:34 AM
Speedster577's Avatar
I am haveing the same problem . I just had plugs put in and the injectors cleaned at the dealer and I am only getting about 10mpg . I have a 2000 F150 with the 5.4 . If there is oil on th MAF sensor how would you clean it off ? Can you use carb cleaner or brake cleaner ?? Everyone I talk to says that I should be getting like 17mpg or more out of this truck but I dont.
My only other thought is the cold air induction is making the fuel inrichment stay on longer or on all the time .
Old Jan 22, 2007 | 08:50 PM
I would use electrical parts cleaner, but that's just me. I don't know what is recommended by ford....
Try putting your old intake back on, and see if it fixes your fuel mileage problem.
Old Jan 23, 2007 | 12:04 AM
FordsRock98's Avatar
electronic parts cleaner or intake cleaner only, dont use carb/brake cleaner your talking about cleaning an electronic part.
