Removing / Gutting Catalytic Converter and Shorten Exhaust
Old Sep 18, 2006 | 07:56 PM
csonka
Guest
Posts: n/a
NomNomNom
Old Sep 18, 2006 | 08:05 PM
98Navi's Avatar
5.0's sound great with hollowed cats. I'd still dual it out the back for the maximum potential sound without headaches in the cab.
You can gut it and leave it on, or take it off and weld in a section of pipe, or if you have emissions you take off the cat, measure it up, get a piece of pipe and weld on the fittings and make a piece that you can take off and replace at your disposal for emissions testing!
Old Sep 18, 2006 | 08:35 PM
98Lariat4.6's Avatar
I was thinking the same thing for my 4.6L, but with a dual outlet. Would it sound any good or not? I don't have emissions to worry about.
Old Sep 18, 2006 | 09:41 PM
humbleautosales's Avatar
do it, i did it with my 95 mustang and it was one of the best bangs for my bucks alot more sound and hp.
Old Sep 18, 2006 | 10:57 PM
csonka
Guest
Posts: n/a
NomNomNom
Old Sep 19, 2006 | 08:18 AM
Norm's Avatar
I am sure you all know this but gutting your cats is illegal. Just because they do not check you does not make it OK. High flow cats are cheap and keep you legal and stops you from poisoning the environment. You may not care but your grandchildren might.
Old Sep 19, 2006 | 11:54 AM
csonka
Guest
Posts: n/a
NomNomNom
Old Sep 19, 2006 | 12:44 PM
charmill26's Avatar
how do you go about gutting your cats?
Old Sep 19, 2006 | 12:45 PM
i like off topic the #1 source of green house gases = volcanoes
Old Sep 19, 2006 | 01:04 PM
csonka
Guest
Posts: n/a
NomNomNom
Old Sep 19, 2006 | 01:55 PM
way fast witey's Avatar
i was always told to take a pipe that just fits inside the cat and hammer it through to bust it all out.but when i tried this with mine,and a sledge hammer,it didn't work.so i used a combination of a longass drill bit,a hammer and a crow bar to drill it to weaken it then the hammer and crow bar to break it up and dumped it all out.
i still wanna know why we have to have cats,yet those bastard cows get to strut around fartin wherever they please and nobody says anything to them.
Old Sep 19, 2006 | 03:01 PM
Norm's Avatar
Originally Posted by csonka
Please note that this is not entirely true. This depends on which state, county, city, etc. you live in and how your vehicle is registered and/or classified. Moving on, any thoughts on my questions my fellow F150 community?
And about the grandchildren. The use and effectiveness of catalytic converters is highly disputable. Please, let's stay on topic.
-Patrick
www.pdub.info
Cats are FEDERALLY mandated so it does not matter where you live in the U.S. of A. If your vehicle came with them and it is driven on AMERICA'S roads you are required by law to have them. If it is an off road or race vehicle then you are correct. There is no dispute about whether cats work, it is proven technology. You may dispute their neccessity but their use and effectiveness have been proven. It is simple science.
The topic was cats and I stayed on it.
Old Sep 19, 2006 | 05:50 PM
98Navi's Avatar
The effectiveness has been questioned by many studies, with variences from the added weight, added cost, and other associations as to the true effect they actually have. Most of the worst emissions of fumes from an internal combustion engine happen in the first 5 or so minutes, when the cat has not yet effectively heated up and become operable.
Back to topic though.....
I don't know exactly what the underside of your truck looks like, but some have a bolt on cat that can be removed by itself. You then simply ram a broomstick or other object that will fit in the pipe through it until you get it all cleaned out (which may take some time) Note though, you should wear some sort of breathing apparatus, like a cheap mask a doctor wears, as the stuff in there isn't good for you at all.
Also, havin a 95 model should make it easier, as there is no OBDII to fight with so you should get away without any modification other than simply getting it off (which can be a biatch) and hollowing it out.
Old Sep 20, 2006 | 11:19 AM
csonka
Guest
Posts: n/a
NomNomNom
Old Sep 20, 2006 | 07:15 PM
98Navi's Avatar
One last note for you (and either way you go doesn't matter nor bother me)
Think of it like this.....You buy catbacks to reduce backpressure and free the flow to allow maximum air to get in and out of your engine. The cat in your exhaust is like you being a size 40 but wearing a size 38 instead. It would work, however it would also impede you from being normal with a tight waist line and cramped *****. If you haven't, I suggest you look up information on cats (which there is a lot of) and see what they look like. Basically, a large obstruction with hundreds of small square holes. IMO, any obstruction is a bad one, but in my case I had to have them so I used the smallest ones I could find. Best of luck
