Why all the flak from Muffler shops
Old Feb 10, 2006 | 04:50 PM
casper99's Avatar
Angry Why all the flak from Muffler shops
I've call most every muffler shop in three counties and all I get is horror stories about the type of exhaust I want.
Looking at duals with a magnaflow DI/DO 14" muffler with Tru-X and 2.5 pipe.
I've heard everything from your computer will shut down to gas mileage will drop to 10 mpg.
Any idea what gives?
Old Feb 10, 2006 | 05:14 PM
Flareside150's Avatar
Sounds like bs to me 10 mpg!!! I have a flow 40 series and I lost a little low end on my 97 4.6. You can buy maggie's stainless kit in the upper 400 range. I've seen that many people go to www.hottexhaust.com for the lowest price after punching in the code (if someone could help). Good luck.
Old Feb 10, 2006 | 06:19 PM
max mitchell's Avatar
They're mainly undereducated monkeys that are expected to assimilate dynamic engineering principles for every vehicle on the market. Individual retards in a group commonly offer differing opinions. Reasonably bright groups commonly form a consensus of similar ideas. This is why pre-engineered cat back sales are brisk.
"Your computer will shut down and your gas mileage will drop to 10 mpg."
Old Feb 10, 2006 | 06:21 PM
rooster2005's Avatar
HottExhaust code = fordtruck8
Old Feb 10, 2006 | 06:22 PM
fourpointsix's Avatar
Morons! You will gain power and MPG. Good luck in your search for an exhaust shop that isn't run by an idiot!
Old Feb 10, 2006 | 10:42 PM
98Navi's Avatar
I saw one today for you guys. Simple as it was, a magnaflow added at the y pipe si/do with a quick 90` elbow to the front of rear tire side exit. Cost with everything, $175. Who needs to pay them $400 for a catback?
Old Feb 11, 2006 | 12:21 AM
01x4x4x's Avatar
HEY! Cooter is the best mechanic there ever was..........
Old Feb 11, 2006 | 12:22 AM
SSCULLY's Avatar
Some shops are just dopes !!!
Here are the pictures of my '01 SCrew 2WD with a L Bassanni Cat back installed on it. Took out the facotry Y pipe, turned the driver's side at a 90* ( mandrel bent 90* ) and put them into the Bassani X pipe and on to the 2 SI/SO mufflers.
Picture of the Turns in the Bassani Kit ( comes this way for the L )
Tips exiting in front of the rear wheel, stock L location.
A bit of additional bending of off sets was needed, due to the retro fit of the L system on a NA engine. If you are starting out with just the muffler and X pipe, and the remainder is DIY, then it would not be quite so bad
If I would have just found some L headers that someone took off for some long tubes, I would have had an easier time of it.
Take a look for a speed shop that does custom work, they won't feed you the BS.
