Whats This Piece In Exhaust Answer Asap
Old May 8, 2005 | 09:57 PM
351FordGuy's Avatar
im cutting my cats off to get new ones put on tomorrow, and i know the o2 sensor is in front of both my cats on a 95 Ford F-150, but what is the metal Hose that connects to the exhaust inbetween the cats?
Old May 8, 2005 | 10:42 PM
Eyescream's Avatar
May be your EGR pipe. Have you tried to trace it from where you know it starts to where it ends up?
Old May 8, 2005 | 10:50 PM
351FordGuy's Avatar
goes up towards the engine bay area, but i lose where it goes to. part way up theres a thing shaped like a spaceship on it that it goes through. I cut off my cats and its just hanging under there right now. Bringing it to the exhaust shop tomorrow to get true duals welded up. Wohoo, but id still like to know what that pipe is lol.
Old May 8, 2005 | 11:27 PM
Eyescream's Avatar
I haven't had the truck long, and haven't done much poking around at it; but if it's a smallish diameter pipe that comes into the exhaust in front of the cats it sure sounds like an EGR pipe to me. It's part of your emissions equipment.
Old May 8, 2005 | 11:42 PM
351FordGuy's Avatar
its inbetween the 2 cats, because theres 2 pipes infront with an H in it with the o2 sensor, then the 2 pipes go into the front cat, a single pipe comes out, theres a metal pipe about 1" in diameter or so, then the other cat, then the rest of the exhaust. i was told i wouldnt get a service engine light for when i cut the cats off because the o2 sensor is infront of the cats. is this correct?
Old May 9, 2005 | 12:43 AM
Eyescream's Avatar
As long as you've still got an 02 sensor screwed into the pipe somewhere and still connected to the computer so it can send it's data, you can pretty much do whatever you want with the exhaust.
As for whether it's a good idea or not is subject for a different discussion.
Old May 9, 2005 | 01:12 PM
colvin's Avatar
that pipe is your air injection for the second cat and that space ship looking thing is a check valve.fords air injection comes from the back of the cylinder heads.
Old May 9, 2005 | 07:53 PM
351FordGuy's Avatar
got the exhaust on and i highly reccomend it. Only thing im pissed off about is they didnt have the exhaust tips in they told me they did so they didnt put any on yet, so i am going to look for a set. not as loud cuz no tips to echo the sound, but it sounds great. wheres a cheap place on the internet to get stainless tips angle cut
