Back Pressure
Old Apr 5, 2005 | 06:59 AM
BLUEWORKHORSE's Avatar
Back Pressure
Im looking to regain some lowend torque back. I stomped on the gas and i only heard noise no power. It used to throw me back in my seat. I have no cats with mag mufflers 2.5" dual pipes. Any help would be great. Ive heard add an h pipe. But any other suggestions would be great.
Ben
Old Apr 5, 2005 | 07:10 AM
APT's Avatar
APT
Dual 2.5" should be fine for the 5.4L. No cats though, are you using MIL eliminators?
You can add an X-pipe (skip the H) for a little power. Go back to stock tire size would be the most effective, though.
Old Apr 5, 2005 | 11:12 AM
racerf150man's Avatar
off the subject a little bit... but what was the stock tire size even??? i dont kno anyone around here that has it lol!
Old Apr 5, 2005 | 11:28 AM
APT's Avatar
APT
All naturaly aspirated 97-05 F-150's have dual 2.5" pipe, into a (very poorly designed) y-pipe with 2.5" all the way to the tip.
Old Apr 6, 2005 | 08:53 AM
Brian42's Avatar
If you want torque back then you want to go back to the Y-pipe setup. True dual (or even H-pipe) robs some low- to mid-range torque to gain high end horsepower.
With the Y-pipe you get a little more backpressure which helps scavenge the spent air/fuel mixture on the exhaust stroke.
Old Apr 7, 2005 | 09:50 PM
way fast witey's Avatar
i have true dual straight pipes with an h pipe and didn't lose much low end.so i'm sure if you had an x-pipe and good mufflers it shouldn't have much less low end than stock.try usin a piece of 2 1/4 pipe thrown in with an x pipe.
