exhaust idea
exhaust idea
right now i have the 4.2L with a flowmaster 40 series. its a 1 in / 2 out. i am considering cutting it where it Y's and running seperate pipes for each side. I would have magnaflow mufflers flipped so they could be installed right next to eachother. I would also have the 4 cats cut out and replaced with 1 magnaflow high flow per side.
anyone know what it will sound like? Is it a good idea? thanks
if your going for sound its great, try to get the mufflers under the factory heat sheild. i would consider an X or H pipe so that you dont lose too much low end, i hope you have read enough on here to realize you will lose your low end tq so be prepared, this is mainly a sound exhaust unless your redlining all the time. show some pics if you decide to go with it
