True Dual exhaust system
Old Dec 8, 2004 | 01:15 PM
Miles73003's Avatar
Does anyone make an out-of-the-box kit for true dual (with two mufflers) or do I just need to purchase a couple of mufflers and head down to the local muffler shop to get the pipes put on? Thanks in advance.
Old Dec 8, 2004 | 01:27 PM
way fast witey's Avatar
there wouldn't really be a bolt on kist,because of the y-pipe.if there was you'd have to replace the entire system,andit'd be cheaper by far to just have a muffler shop do it.
Old Dec 8, 2004 | 01:34 PM
bonefish's Avatar
Excuse me for being dumb, but what is the Y pipe, what does it do, where is it at, etc.
Old Dec 8, 2004 | 07:29 PM
max mitchell's Avatar
Not dumb ! On most F-150s, the 2 headpipes merge into 1 single pipe. They join at a "Y-intersection". Y's can also split 1 exhaust pipe into 2 separate pipes, like when adding fake duals. "Y-Pipes" are generally aftermarket, universal, removable replacements. Here is an example:
http://www.f150online.com/galleries/...w.cfm?num=2504
Old Dec 8, 2004 | 07:38 PM
bonefish's Avatar
So what would be better. #1-To split the pipes at the factory Y pipe and run two mufflers and then out the back. #2-Buy a muffler that is SI/DO and then out the back. #3-Buy a SI/SO and put aY pipe after that and out the back.
On a similar not which would retain the most backpressure, I have a 4.6 and need all the tourqe I can get.
Old Dec 8, 2004 | 10:30 PM
openclasspro#11's Avatar
full kit
contact- www.spintechmufflers.com- they have full dual exhaust kits for 97-03 f's with x pipe included!
Old Dec 9, 2004 | 10:53 AM
#1 is fine (true duals). Properly size pipe and muffler to 2.25". Provides a small top-end improvement and works well with substantial mods.
#2 is what most of the pre-engineered cat-back's do. It's simple, effective, lighter, cheaper, and fewer parts. It also has less fitment issues and performs well on stock to mild trucks in the low to mid range rpms for maintaning your torque.
#3 needs a shorter muffler placed forward to leave room for the Y-Pipe. Personally, this would be my last choice.
Old Dec 9, 2004 | 06:27 PM
bonefish's Avatar
If I go with # 2 should I still go to 2.25" pipe after the muffler.
Old Dec 9, 2004 | 07:51 PM
you should also check on getting a muffler and having a local shop install it/run pipes.it's usually cheaper that way.
Old Dec 11, 2004 | 10:12 AM
Yes, but it's the SINGLE intermediate pipe, forward of the muffler, that will limit your flow.
Old Dec 11, 2004 | 12:16 PM
mrjamjam's Avatar
Match the muffler inlet size to the single pipe coming from the Y pipe. This should be 2.5" on your truck. Then run 2" or 2.25" duals out the back. With the 2.5" pipe it is difficult to get the clearance around the spare tire. If you want a deeper sound, use a large 3.5 to 4" tip. I would ask for mandrel bent pipe.
I use a Y after the muffler to get the dual look on my truck. The muffler is a 3 SI/SO by Aero Turbine. But I did this just because I wanted the dual look and I wanted to use the Aero Turbine. The duals are 2.25" with 3" tips. It has a great deep sound when I'm on the gas and quite at cruise. Got it all done for $250.00. I do wish I had changed the front Y pipe with the magnaflow Y pipe and run 3" to the muffler.
