Center cap/exhaust problem
Old Jan 1, 2001 | 01:46 AM
Cowlady's Avatar
Question Center cap/exhaust problem
I know that alot of you have had your center cap dull from the exhaust exiting in front of the rear tire. I have the same problem & will have the exhaust routed behind the tire when I need to replace it BUT the exhaust is new so that won't be for awhile hopefully!
In the meantine, I was thinking of getting a curved tail pipe extension & turning it so the exhaust exits toward the front of the truck. Do you think this will work? Any problem doing this since it would end up exiting toward my nerf bars? I want to get a new center cap but not if it will happen again! If this is a bad idea I guess I'll have to live with the old center cap till I replace the ehxaust.
Thanks for the help!
If you can't beat 'em, you're NOT driving a FORD!
'97 Black F150 XLT ORP 4X4
4.6L/auto/3.55 LS/power EVERYTHING,
nerf bars, 17" wheels, fog lights, trailer hitch w/electrical connector, front tow hooks, bed rail caps,
6 CD changer, lumbar support & 3 cow license plates - so far!
I'll fill in the rest as I get to know the truck better BUT it's big, it's pretty & best of all - IT'S A FORD! He's SO cute!
Shovies PROVE that Ford's are #1!
Old Jan 1, 2001 | 02:47 AM
nomo's Avatar
Post
I'd recommend not pointing the pipe forward. Among various reasons, you'll still be driving through the gases. Not sure how much it will help, but you could try pointing the tip downwards.
Old Jan 1, 2001 | 08:30 AM
Cowlady's Avatar
Wink
Thanks nomo - EXCELLENT suggestion! I think I will give it a try - I'll let you know how it works! Have a great New Year!
[b]If you can't beat 'em, you're NOT driving a FORD!
Shovies PROVE that FORD'S are #1!!
Old Jan 7, 2001 | 12:30 AM
Hywaystar's Avatar
Registered User
Post
I agree with pointing it down, you might even want to take as few inches off the existing pipe before adding the turn-down. that way the exhaust will be inside the wheel. Turning it to the front will allow rain/road spray to enter the exhaust system which will eventually blow back out as black soot.
1997 F-150 4X4
5.4L
Automatic
LeBra Tonneau
K&N Filter
Gibson Exhaust
B&M Shiftplus
Xeonblue Lightbulbs
Foglights without Headlights
Torsion bar level
jopamu@yahoo.com
Old Jan 7, 2001 | 02:38 AM
Cowlady's Avatar
Talking
I like your idea! I'm going to try it & then if it works I'll get the new center cap. BTW - any suggestions on the best way to clean/polish the other 3 caps? They're just a little dull & getting a new 1 will make THEM look bad!
Old Jan 7, 2001 | 04:47 AM
Hywaystar's Avatar
Registered User
Post
I find that regular washing keeps them clean.
If they are that bad, I would use a metal polish; Mothers and Eagle One are very common.
1997 F-150 4X4
5.4L
Automatic
LeBra Tonneau
K&N Filter
Gibson Exhaust
B&M Shiftplus
Xeonblue Lightbulbs
Torsion bar level
jopamu@yahoo.com
Old Jan 8, 2001 | 11:46 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Post
I use Mothers "clearcoat wheel polish" it's
awesome stuff! Polishes the wheel and eats up brake dust like it's not there,,,,,98
Another solution is that J.C. Whitney now sells the center caps for $69.95 a set,whenever it gets dull you could switch it out. This could last a few years ,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Stillen Quad light air dam, sweet!!
Euro taillights
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper alarm
On the way/wheels,tires, etc..etc.......
the monochromatic boogie is done,cool!.
Come see my new pictures@ www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
[This message has been edited by 98SCREAMER (edited 01-08-2001).]
[This message has been edited by 98SCREAMER (edited 01-12-2001).]
