I am researching duel exhaust
Old Nov 8, 1999 | 09:55 AM
Michael Reschke's Avatar
Post
I'm back.
OleFordHead,
Yes I did get my system done. I ended up having a cat back system installed at a local shop. I put on a Dynomax Race Magnum muffler after the converter and they bent 2 1/4' dual pipes out the back to 3 1/2" stainless cans. The shop guy insisted that spending the extra money for 2 1/2" pipe would not make a difference on the 4.6 worth noticing. I still wonder if that is true. It does sound good. Like a Stang Cobra. The Race Magnum was louder than a Super Turbo and much healthier. It's definitely not to loud. The shop let me hear after cutting off my old muffler with it straight out of the converter. Then he tried each of the Dynomax mufflers. I haven't heard a Flowmaster to compare to. I would like to hear other one to compare with mine. Overall I am pretty happy with what I ended up with. They did a nice and clean job. The stainless cans are a nice touch and needed up here in Minnesota.
'97 F150XL 4.6L 5 spd 4x4 SC, Silver Frost Clearcoat Metallic,
265/75-16 Wild Spirit MPT tires on factory steel wheels, K&N air filter, Leer fiberglass topper, Access Roll-Up Cover, bug deflector, rear custom Ford mudflaps, Pendaliner, Pioneer Supertuner CD, 4 Cerwin Vega Speakers. Future mods: BFG's and wheels, shocks, Superchip, stainless rocker panel guards, dual exhaust for starters.
* 9/27/99 installed Factory Ford 60/40 seats from Sonny's
* 10/13/99 installed cat-back exhaust system with dual pipes out back, a Dynomax Race Magnum muffler, and 3 1/2' stainless slash tips.
FOR SALE - Leer Signiture Series fiberglass topper. 6 months old. Loaded: tinted automotive glass, cab slider, tilt out rear windows, carpet, brake light, colormatched Silver Frost Metallic ('97 F150). $850
Old Nov 10, 1999 | 08:12 PM
Don C's Avatar
Exclamation
I just want to put my two cents in. It all depends on where you want to increase your power, low RMM's or Higher RPM's.
In my last truck a 1993 Lightning I put on equal length headers, two flowmaster mufflers with 3 inch pipes, after driving it I found out I reduced my back pressure to much. The truck had more power at higher RPM's while lost power at lower RPM's.
So I replaced the pipes after the mufflers to 2 1/2 pipes,then my low end power was much better, as well as the higher RPM power.
With small block engines, you still need some back pressure, if you wish to retain your low end power, and how often do you drive over 4000 rpm's anyway.
On my new f-150 I just ordered a Bassani single cat back systems. It should give me more power and millage in the RPM range that I will be using most often.
Hope this helps.
Thanks Don
Old Nov 11, 1999 | 12:30 AM
OleFordHead's Avatar
Arrow
don, yep thats one of the things i'm worried about, loosing the bottom end. rather than going to true duals i'm thinkin i'd be better off buying a cat back system and headers. i dont like the forward of the rear wheel exit though. i'd still like "duals" out the back. whats the bassini gonna run ya anyway?
Old Nov 11, 1999 | 08:58 AM
Don C's Avatar
Cool
Old Ford Head
It cost me $409.00 at http://www.racesearch.com
It exits our in the stock position behind the rear wheel. I will let you know how it works out, should have it installed by next weekend.
Old Nov 11, 1999 | 03:44 PM
RED-ONE's Avatar
Wink
I had a local shop put my true dual exhaust on and they too let me start the truck up after cutting off the exhaust after the aft oxy sensor. Sounded just like the good old days...
They cut the "Y" pipe and custom bent the new pipes into place welding and putting seven hangers into place. I picked 36" glass pipes along with the 2 1/2" aluminum coated pipes all the way out the back with 3 1/2" chrome resonator tips. The installer guy said this would keep enough back pressure for low end torque that is usually loss when opening the exhaust up. The guy who did this took his time and was careful to weld the piping up good and clean and paint all the joints. He said that the new Triton engines don't sound as good without mufflers as the older small block Ford engines do. I too don't want to **** off the neighbors each moring when I leave for work so I picked something that was toned down a little bit.
The only question I have for everybody is this guy did not put in a "H" pipe. Is this necessary and what does it do?
RED-ONE
Red/Silver '97 F150 4x4 SC Lariat LB, 5.4L, Auto, 3.55 LS, Grey Leather Buckets, Tow Package, Everything Else, 10 disk CD changer, K&N air cleaner with housing modification, True Dual Exhaust out the back with chrome tips, 36" glasspacks, Nerf Bars, Extang soft top cover, color matched front Bug Deflecter, window drip guards, cranked torsion bars, custom spring pack for rear, Michelin LTX A/T LT265/75/16.
5700lbs of rolling blue oval fun.
