install - leave it to the pros?
Old Jan 14, 2004 | 01:22 AM
lrudduck's Avatar
Question install - leave it to the pros?
I'm looking into MagnaFlow cat-back exhaust for my 04 150 Screw. Is this something I can install myself? That is, loosen a few bolts here and there, pull out the old, put in the new, tighten a few bolts and I'm done. Or should I have it professionally done.
Typically I don't do my own work since it's not my forte but if this doesn't require a lot of skill I'd like to save the install cost.
Old Jan 14, 2004 | 08:35 AM
Spaceman Spiff's Avatar
from what i have seen here on the boards, it is simply taking the factory exhaust off and then replacing with the magnaflow. some suggest taking it to a muffler shop to have it tack welded into place afterwards, just so it doesnt come off later. but it should be a fairly straight forward job.
Old Jan 15, 2004 | 10:05 PM
frdstpsd98's Avatar
Replacing an exhaust is fairly easy, especially on an 04. All the factory bolts and hangers havent had a chance to really rust yet.
A friend and I replaced the factory exhaust on my 93 chevy and that was rusted solid. It only took a couple of hours. All kits come with everything you need, its just a matter of selecting the muffler you want to go with it. All you really need is basic wrenches and sockets and you'll be all set.
Old Jan 15, 2004 | 11:11 PM
kaliscrew2k2's Avatar
Most importantly, don't forget to have some type of pipe cutting device/ machine. Most kits REQUIRE CUTTING. If you're not up to it, get it professionally installed.
Old Jan 16, 2004 | 06:16 PM
OzarkExpedition's Avatar
I just replaced my exhaust with a MagnaFlow catback system and it wasnt that difficult. Standard wrenches and something to cut the old pipe if needed. I would also suggest WD-40 or PB Blaster or something if your factory clamps and pipes are rusted. I also used some silicon spray on the hangers to make it easier to remove the factory system. I think if you dedicate yourself to the task and arent afraid to put some muscle into it, you can do this. Save yourself the money and give it a shot. Good luck!
Old Jan 16, 2004 | 09:52 PM
rbraughn's Avatar
Do it yourself. I did it in about 45 minutes including clean up. If you don't have a sawzall (I had to make 1 cut), get one of those cut off discs that go on a circular saw, it will cut like butter.
