Exhaust Question
Old May 12, 2003 | 11:25 PM
2002S-Crew's Avatar
Exhaust Question
I'm looking for a system that will give me the best power while still running 89 octane. I'm not worried about the noise eather.
I have a 2002 Super Screw.
Also what else can I do performance wise?
Old May 13, 2003 | 01:01 AM
beastie's Avatar
If you want just a bolt on cat-back, get the Magnaflow cat-back, it is the only system that you will gain low end torque with, plus it still makes more peak hp/tq than any other sysyem. If you want to go all out, you can get a true dual Magnaflow ... hiflow cats, x-pipe, dual mufflers, this will be the ultimate setup, but it will require a shop to custom bend all the pipes and put it together.
As far as other mods, get a Superchip, and an Air Force One Intake. Those will be the best bang for your buck mods along with exhaust. Next I would get underdrive pulleys, conver the factory clutch fan to dual 16" fans. Then add some headers, get a larger throttle body, put some 4.10 gears in, and a limited slip if you don't already have one. Add a shift kit for your transmission, then you can add a blower, port your heads, get cams, .... the list goes on.
Old May 13, 2003 | 01:22 AM
2002S-Crew's Avatar
How much will "true dual Magnaflow ... hiflow cats, x-pipe, dual mufflers" cost?
I have $200 so far, I know I will need alot more.
Old May 13, 2003 | 07:28 AM
APT's Avatar
APT
In order of power/$:
Superchip
Electric fans
Exhaust
Pullies
Old May 13, 2003 | 12:06 PM
2002S-Crew's Avatar
what do the electric fans do? Where would I purchase them from?
Old May 13, 2003 | 12:17 PM
APT's Avatar
APT
The F-150 uses a fan that is connected to a pully on the serpentine belt. This takes up some of the engine power to turn the big fan. Electric ones use electric motors which are more efficient than the pully.
There are several kits availible, and plenty of custom ones you cna read about on here. Search for "electric fan" in the engines forum. Also, Mike T in the superchips forum sells a nice kit.
Old May 13, 2003 | 12:40 PM
2002S-Crew's Avatar
SO is this what I need.
Stage 2 Performance Package for '97-'99 Ford F-150/Expedition, Micro Tuner
Superchips Micro Tuner for optimization of the powertrain programming, the Air Force One Intake System to relieve restriction in the air intake tract, a complete Magnaflow Cat-Back Exhaust System to relieve restriction on the exhaust side of the engine, our PPI Dual 16" Electric Fan Kit, Underdrive Pulley Set & complete High-Performance Ignition System upgrade,
This package adds approximately 70-75 HP & 80+ lbs./ft.
$1850.00
OR
Stage 5 Performance Package for '97-'99 Ford F-150/Expedition
Allen Engineering Supercharger Kit
2-program Superchip Flip Chip
Complete set (8) of 36# high-performance fuel injectors
80 mm Granatelli MAF
75 mm Edelbrock/BBK Throttle Body.
The Air Force One Intake System
JBA Headers *with* Jet-Hot ceramic thermal barrier coating
Magnaflow High-Performance Catalytic Converters
Complete Magnaflow Cat-Back Exhaust System.
Our PPI Dual 16" Electric Fan Kit.
Complete High-Performance Ignition System upgrade
Transgo Shift Kit and our Troyer Performance Active Automatic Transmission Cooler System
This package adds approximately 175-190 HP & 150+ lbs./ft.
$7625.00
Old May 14, 2003 | 07:24 AM
APT's Avatar
APT
$1850.00
$7625.00
You've got a long way to go....
Actually, I was thinking:
Microtuner or Superchip
Magnaflow #15609
Pullies
Or, the Stage 1 kit. I think that would greatly increase your driving experience.
Old May 14, 2003 | 10:16 AM
SSCULLY's Avatar
Re: Exhaust Question
Unless this part of your requirements went away, no MicroTuner.
You would need to do a chip with a tune for 89 oct, which is not as strong a tune as the 91 + tune.
2x check it with Mike to be sure, but I don't think 89 and MicroTuner can be used together.
Old May 14, 2003 | 02:01 PM
2002S-Crew's Avatar
Reason I want to run 89 is I get it at half price, or less.
Old May 14, 2003 | 02:37 PM
2002S-Crew's Avatar
Probally take me a few months to get the $8000. If the canadian dollar gets any better, it will take less time.
I think I may go with the stage 1 kit for now. I can run 89 on both kits with a 5-10hp power lose. Hmm, what should I do. Maybe go with the stage 1 now, and upgrade to stage 2 later.
2-program Superchip Flip Chip or micro tuner
65-72 HP & 75-80+ lbs./ft. of torque to the 5.4
$1850.00
Stage 1
45-50 HP
$999.95
Old May 14, 2003 | 03:55 PM
SSCULLY's Avatar
I'm not questioning why, just pointing out no Mirco Tuner for this. Needs to be a chip with the correct tune. I saw suggestions for the Micro Tuner in posts, and wanted to point that part out.
Like I said ask Mike if the Micro Tuner has the ability to be programmed for 89, I did not think it was an option to take in the programming. I don't recall seeing that as an option, but then again I did that quite awhile ago.
Old May 16, 2003 | 12:03 AM
OTrizzlePhatRid's Avatar
oR sell the truck you have now, take that 8 grand and buy a harley supercrew which has the performance transmission, 20 inch cromies, and a hell of a nice interior...not to mention the huge blower.
