Magnaflow Muffler Question
Old Apr 29, 2003 | 04:10 PM
sxmax's Avatar
Magnaflow Question
Is the 5x8x24 the muffler that comes in the 15609 kit? If not, what does? Looking to do a 3" SI/SO on my supercrew without getting the whole kit. What would the correct PN be?
Thanks!
Old Apr 30, 2003 | 11:32 AM
sxmax's Avatar
Please?
Old Apr 30, 2003 | 11:46 AM
APT's Avatar
APT
I believe it is a #14229 that is polished to a mirror finish, unique to the system, but same base part. 3", offest in, center out.
Old Apr 30, 2003 | 12:56 PM
sxmax's Avatar
Another question!
Is there any sound difference between a center in, center out versus the offset in, center in? What would the difference be in the different lengths of mufflers as far as sound is concerned?
Thanks!
Old Apr 30, 2003 | 01:54 PM
APT's Avatar
APT
I'll give you $50 if you can tell the difference in sound between a Magnaflow center in, offset, or any combo, assuming the muffler is the same size. Magnaflows are a straight through design. Center-center would be simple, any offset would still be striaght through, but on an angle relative to the centerline of the muffler. Anyway, you won't notice any difference between them in sound or power.
However, generally size (actually volume) of a muffler relates to sound level, given the same muffler design. The larger the muffler (more insulation), the quieter. Tone should be similar given the muffler design, although larger may = slightly deeper vs. sometimes tinny of smaller canisters.
Old Apr 30, 2003 | 02:06 PM
sxmax's Avatar
Thanks!
Thanks APT! I think I have my questions answered. Now off to the store or online to pick one up and have it installed!
Thanks Again!
Old May 8, 2003 | 03:10 AM
mf150's Avatar
How many of you guys have welded the Magnaflow system. Also, what material would you recommend as a welding agent so that the weld doesn't rust?
Old May 8, 2003 | 11:07 AM
LE PEW's Avatar
If I had to install a stainless system I'd ask the shop to use stainless wire on their mig welder. It would look nasty to see rusty welds on a nice stainless sytem.
Good luck.
Old May 10, 2003 | 02:36 PM
wally9404's Avatar
just had magna flow headers installed on my 2002 lightning,along with long pipes and magna flow muffler,headers were ceramic. only thing i picked up truck and still had only one muffler, also am running a 8lb pulley,super chip flip chip,airaid intake,truck s supercharger is being bored and polished now. had the truck dynoed 1 week ago before exhaust system installed, i had 406 hp rear wheel and 528 torque,took it back sameday i picked ip truck,dynoed403 and 405 rear wheel and 538lb of torque, was expecting a whole lot more,what happened, do i have to have chip reprogrammed. anybody got any answers. thanks wally
Old May 11, 2003 | 05:22 AM
mf150's Avatar
Le Pew~
Do most muffler shops have Stainless wire? Where can you get the stuff?
THX
Old May 13, 2003 | 09:16 AM
LE PEW's Avatar
Sorry to reply so late. I would hope that a decent muffler shop has stainless wire for their machine but no telling for sure unless you ask up front. Even if they dont use it on every job it's no hassle to switch the spool over in the machine.
