Exhaust Routeing
Old May 7, 2001 | 01:24 PM
SuperCrewser's Avatar
Question Exhaust Routeing
I have a 2001 S-Crew 4x4 lariat and I have heard alot about dual exhaust out the back. The problem I ran into was that I wanted semetry one pipe on each side of the spare not two outs on the side. I don't want to boil a driver side shock or run to close to the gas tank. My local exhaust shops told me I would have to drop the spare to get my 2 out the back. Also is there such a thing as 2 much exhaust - like dual 3"s 1 from each cat? HELP!
Wendell
Old May 7, 2001 | 02:28 PM
OneBadCrewX4's Avatar
Post
I'll post my picture of mine later today. The shop actually ran under the spare a little bit.
2001 SuperCrew ORP 5.4L Gen I
MODS-Ramsey Brush Guard and Pro Plus 9000 winch, MAAP steps, Airaid, True Duals w/ 50 series DF muffs, Line-x, bugflector, and huskyliners.
http://albums.photopoint.com/j/AlbumIndex?u=1508480&a=11420452&f=0
Old May 7, 2001 | 07:18 PM
JA4x4's Avatar
Post
yes there is such a thing as too much exhaust size.with the exception of supercharged motors.
true dual 3inch pipes on a small block is way too high by my book. backpressure is used to help pull air in the intake valve. there is a very slight time when both valves are open at the same time. if you eliminate this backpressure, you loose power.
nearly everyone i ever talk too about exhaust, including a former NRHA top fuel car driver, has told me that 2.5 is the best single pipe and 2.25 is the best dual pipes for low end torque.
this doesn't mean you can jump up to 3 or 4 inch tips/exits for sound though.
Old May 7, 2001 | 09:06 PM
Post
Sorry about the size. If its small you can't see the pipe under the spare.
[This message has been edited by OneBadCrewX4 (edited 05-07-2001).]
Old May 7, 2001 | 11:13 PM
kkirt1's Avatar
Post
You can run duals out the back and still get to the spare. It is pretty close on the spare and the drivers side shock but it can be done! I have the setup on my Crew!
Let me know if you need some pic! kkirt1@hotmail.com
Supercrew 4x4 Lariat
Solid Black , 5.4 Triton, 3.55 Limited Slip, 6750# GVWR Package, Skid Plates, Moon Roof, Sliding Rear Window, Trailer Tow - Class III, Cargo Cage, Grey Leather Captains Chairs, 6-Disc CD Changer
Mods:
305/70/16 Goodyear ATS
American Racing Atlas 16x8
Chrome Westin Steps
Flowmaster, Delta Flow 50 SI/DO
Cranked Torsion Bars 1"
Mobil 1 @ 1,000 miles
Concept II Deflecta Shield
Planned:
Toneau Cover
Expedition Console Mod. (Been there, done that - didn't like it so I sent it back!)
Another great Ford truck site -www.fseries.com
Truck Pictures
Old May 9, 2001 | 12:44 AM
Exclamation
I would just like to tell every one thanks for the help. Also kkirt1 did you run the pipe between the shock and spare tire protection plate? Once again thanks for the help and pics.
Wendell
