Any body used an X pipe?
Yes I have one on my SCrew. If I remember I'll post a couple of pic's of it this weekend.
<A HREF="http://www.fpage.com/rbaker/MN-Trap_SCrew_122300.html" TARGET=_blank>http://www.fpage.com/rbaker/MN-Trap_SCrew_122300.html
</A>
2001 F-150 SuperCrew 4X4 XLT – Silver w/Medium Graphite interior,
4.6 V8, 3.55 Limited Slip Axle, P265/70R17 OWL All-Terrain,
17” 10 Spoke Aluminum Wheels, Class III Trailer Towing Pkg.,
Remote Keyless Entry, Dual Media Ford AM/FM/CD Radio & 6 CD Changer,
Captain’s Chairs, Ford Cab Steps – Black, Engine Block Heater
Custom Dual Exhaust with X-Pipe
EGR Carbon Fiber Hood Shield
Window Vent Shades
Outland Grill Guard – Black
PIAA 9051 Ion Crystal Fog/ Clear Driving Lights
Superchip
Airaid Intake System
A.R.E. LSII Hard Tonneau cover with remote lock
Python 1500 ESP Security System w/remote start
Clear Corner Lenses
Rhino Liner
TruckVault
Infinity Kappa 50.2cs in front door
Infinity Kappa 572.1cf in rear doors
Valentine One w/Laser Radar Detector & Concealed Display
2000 Expedition Console
J&J Stainless Grille Insert
Lund Moon Visor
Pop-Lock in tailgate
</A>
Window Vent Shades
Superchip
Clear Corner Lenses
Rhino Liner
TruckVault
Lund Moon Visor
97Triton4.6, here are a couple of pictures of my x-pipe installation.
</A>
Window Vent Shades
Superchip
Clear Corner Lenses
Rhino Liner
TruckVault
Lund Moon Visor
[This message has been edited by MN-Trap (edited 03-31-2001).]
</A>
Window Vent Shades
Superchip
Clear Corner Lenses
Rhino Liner
TruckVault
Lund Moon Visor
Jimmar, Check out the link in my signature and you'll see where my driving lights are mounted. The x-pipe is suppose to provide less restriction to exhaust flow than the "Y" pipe. Or at least what I've been told.
</A>
Window Vent Shades
Superchip
Clear Corner Lenses
Rhino Liner
TruckVault
Lund Moon Visor
</A>
Window Vent Shades
Superchip
Clear Corner Lenses
Rhino Liner
TruckVault
Lund Moon Visor
You use an X pipe to "mix" the exhaust from each side of the engine when putting in a true dual system. It is supposed to make up for some of the downstream (not at the manifolds) scavenging loss you get with separate pipes all the way through because of cylinder firing order. Older applications or one's with space constraints use an H pipe but it doesn't work as well.
I am not a big fan of true dual exhausts except in the few cars that they were really made for, such as those oldies with the side pipes. Problems with them are tuning the scavenging, extra weight, sometimes many more bends, etc. They just don't make sense under a lot of vehicles.
That said, I have seen some pretty disgusting Y pipe to single applications that make me wonder what they were thinking. I wondered about my 2001 Screw where the "Y" isn't really a "Y" and one side has about 6 bends in it, at least 2 90 degress. That has got to hurt. I wonder why they didn't Y
further back where they could have made it more gradual without adding a lot of tubing weight. Has anyone tinkered with this notion, i.e. the y between the cross members? My gut tells me that properly done (from a diameter perspective) this would outperform a true dual.
Chuck
2001 Gen I Screw Lariat
Air Raid, Superchip
further back where they could have made it more gradual without adding a lot of tubing weight. Has anyone tinkered with this notion, i.e. the y between the cross members? My gut tells me that properly done (from a diameter perspective) this would outperform a true dual.Chuck
Air Raid, Superchip
IMud- The Y-pipe is a poor design. The drivers side pipe is squeezed down to 2.25" at it's Y entry and it enters at a very poor angle for flow.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Hi All
I think the stock Y pipe sucks. If i went with an X pipe would i need to use dual three chamber mufflers ( flow master ) so i dont lose to much back presure?. Right now i have a 40 series flow master single in dual out with the stock Y pipe. (40 series 2 chamber) I also will be installing headers as soon as i can afford them. Can i expect more power with this set up? and a good sounding exhaust?. Thanks for the help.
Larry
Larry
MN-Trap
I forgot to ask what kind of mufflers you are using? also did you lose any bottom end power with the X pipe or did you gain some?.By any chance do you have headers on your truck?.
Thanks Larry
Thanks Larry
Larry, It actually felt like I gained some bottom end. Just stock exhaust in front of the x-pipe. I had the work done at muffler shop in town, that does a lot of custom exhaust stuff for racers. When they put my truck up on the rack and looked at it. They said that Ford actually did a nice job of designing the exhaust on the SuperCrew. Go figure! They put the x-pipe in on the out board side of the Cad's . The mufflers are glass packs that sound really nice! Not too loud but a really nice tone to them.
1st person I've seen that has true dual and glasspacks besides me. Don't have an x-pipe. Click on like below to see pics.
1997 XLT Teal 4.6L Flareside 4x4 ORP. Automatic, Reg. cab, 3.55LS, tinted windows, bug deflector, Dual exhaust, K&N Generation 2 air filter, BullDog keyless entry/remote start, Modern 16" wheels, bedliner, Covercraft tonneau cover, White faced gauges, electronic shift on the fly, Clarion ADX5655z Double Din Cassette & CD, 4 Pioneer TS-A6865 speakers and superchip. Going to add headers.
Future mods: Supercharger, headers, NOS, tranny upgrade(heavy duty gears, clutch packs, etc.), performance torque converter, bore engine 30 over, new pistons, crank, and rods, and performance heads.
Click here to see more pictures
