rust in tips?
Old Feb 27, 2003 | 09:28 AM
jmorg1980's Avatar
rust in tips?
i was going to get high heat paint up to 12oo degrees but i would like a color i could only find in engine paint up to 500 degrees would this be ok for the inside of my megaphone tips?
Old Feb 28, 2003 | 03:04 PM
Ray21's Avatar
I think that should be just fine... I'm not too sure how hot it gets in there but it shouldn't be more than 500 degrees.
Old Feb 28, 2003 | 04:44 PM
mf150's Avatar
I wouldn't worry about the superficial rust in the tips. Take you truck for a long run at freeway speeds and you'll notice the rust will burn off. Certain older car companies, Studabaker (SP?), use to leave their engine blocks out in a yard for up to one year so that the rust would actually harden the metal. Weird huh. If it's not bad...I would worry about painting them.
Just my opinion, good luck
Old Feb 28, 2003 | 06:09 PM
Texcowboy9's Avatar
The only reason I painted the inside of my tips is because I have the rolled edges, even though they have drain holes all of the water splashed in there during the wet weather does not go out the drain holes but overflows over the rolled edge leaving a rust mark. I guess once carbon builds up in there the black will then overflow. Just need to keep them wiped and shined!
Old Feb 28, 2003 | 06:32 PM
mf150's Avatar
Any protection helps in that case!
Just for my curiosity's sake, how'd you paint the interior?
Old Feb 28, 2003 | 10:35 PM
Texcowboy9's Avatar
M150, I just used a spray can with a rag in hand to wipe off any overspray on the chrome, once you put the tip of the spray can in the tip there is only one way it can go, just make sure the drain holes dont clog up. It takes very little paint.
Old Mar 1, 2003 | 09:16 PM
jmorg1980's Avatar
i dount think my tips have drain holes does everybodys?
Old Mar 1, 2003 | 10:42 PM
Texcowboy9's Avatar
If your exhaust tips have rolled edges they should.
Old Mar 2, 2003 | 09:15 AM
jmorg1980's Avatar
here are my tips i dont think i have rolled edges but i dont know
Old Mar 2, 2003 | 10:58 AM
Texcowboy9's Avatar
Jmorg,
Your tips do not have rolled edges the best way to describe rolled edges is a round lip at the edge. If I could figure out how to send a picture i could show you mine.
Old Mar 2, 2003 | 11:13 AM
jmorg1980's Avatar
i buffed them today and put some clear heat paint on them hopefully theyll stay at least this clean looking
Old Mar 2, 2003 | 11:16 AM
jmorg1980's Avatar
texcowboy go to your gallery and view whatever pic you want to put in your message and click the link that says forum codes. Then cut and paste the address that pops up after your message
Old Mar 2, 2003 | 02:10 PM
Texcowboy9's Avatar
Here is the url for the rolled tips
https://www.f150online.com/galleries...w.cfm?num=3625
Old Mar 2, 2003 | 05:08 PM
mf150's Avatar
jmorg~
Looks like you need some new tires. Have you been spinning them j/k
