347 Stroker Motor - New $2500
Old Aug 6, 2010 | 09:08 AM
ArcticCat's Avatar
347 Stroker, everything but the cam/lifters, push rods, intake, carb timing cover, water pump and pulleys oil pan. It has NOT been assembled!
Same package, but with stronger crank. http://www.coasthigh.com/10666-SF-F3...sf-f347-sb.htm
Machine work performed by Automotive Machine in Roseville, MI
http://www.automotivemachine.net/
Stroker Kit: (Probe industries pistons and rods and Scat Crank) Coast High stroker kit - 10666-030-SF-F347 (10.5:1 compression) flat top, forged scat crank, balanced. (CoastHigh.com)
balanced at 50oz.
Heads: Edelbrock Performer EDL-60229 + head bolt kit.
Ford Racing valve covers (Aluminum - The expensive ones)
All the gaskets and bearings. (Fel-Pro)
Late model 302 roller block, machined bored .30 (Virgin Block, was never run, Ford Surplus sold at Summit)
roller timing chain set
PRO roller rockers
Easy 360-385 hp, if not more depending on your cam/intake and carb choice... Machinest said I was being conservative.... Only a dyno will tell.
I have most of the receipts handy.
$4800 into parts and service $2500 takes it home - Priced to move.
Home evenings 5pm to 10pm for pick up - Webberville, MI
If you have question, send me a PM or email me at kenny_b_good@yahoo.com
Ken
