Battery Part Number
Old Nov 9, 2002 | 01:16 AM
LeanNCut's Avatar
Question Battery Part Number
How would you find out the exact part # of the factory battery that came with your truck? The new dealer-installed battery is quite a bit smaller than the original one and the battery cover sits on top of it with 1 inch of free space on each side. Is this normal or did I get a cheaper battery than the one I requested?
Old Nov 9, 2002 | 12:03 PM
T Ellenberger's Avatar
I don't have a part number but, almost all full size Ford vehicles require a size 65 battery.
Old Nov 9, 2002 | 07:55 PM
Old Timer's Avatar
Hi
You didnt say what year truck?
Look in the owners guide book...should list what battery your engine calls for.
If it dosent list cca/res.cap/amp.hr etc...then you have to find out what the rating #s are for OEM batt....then compare those #s to new one.
Smaller batt. with same capacity as orig. maybe...but again...i would ck. to be sure i got at least OEM rated batt. JMO
Good luck...OT
Old Nov 10, 2002 | 12:33 AM
AjRagno's Avatar
I think they may have given you the smaller of the 2 offered. I'm still using the original, from when my truck was purchased in June, 1997. It is the larger, optional battery. I don't have part #'s, but when I called the dealer to check, they did ask if I wanted the standard or larger, optional battery.
Battery (Standard) = 58 amp/hr
Battery (Optional) = 84 amp/hr
