1997 F150 Trailer Tailights not working
I have a 97 f150, the brake lights and turn signals on my trailer are all working fine, but my tailights on the trailer are another story. They are not working. I am assuming the ground is ok because the brake lights and turn signals work. Any ideas of what I can check on the truck itself?
sbailey;
the problem could still be in the trailer... if it is a 4 pin connector wiring should be as follows ...
-White is ground
-Brown is for the tail/marker lights
-Yellow and green are for right & left turn signal
so test between brown and white for 12 volts when truck lights are on ... i had a corrosion prob once with my connector which caused same thing... those are dual element bulbs on trailer i am assuming
if voltage exists at back of truck reconnect plug and test at lamps
good luck.
-White is ground
good luck.
