flasher unit
Old Nov 1, 2002 | 04:52 PM
bni's Avatar
bni
Unhappy flasher unit
For some reason my flashers don't work any longer, can't find the flasher unit and no aftermarket flasher units available. Anyone have an idea. I hooked up to my camper and flashers haven't worked since. Blinkers still working fine except for the problem of putting the signal switch all the way done on the left blinker. Planning to pull the bottom off the stearing column and fixing the wire/switch when time is available. Thanks for any help. BI When I say flashers, I mean Hazards
Old Nov 1, 2002 | 09:13 PM
Wino's Avatar
the same flasher runs both your turn and your hazard lights. so i'm thinking you have another prob. maybe the sw. due to the fact it will not operate on the left turn side very well. good luck
Old Nov 4, 2002 | 09:10 AM
bni's Avatar
bni
Thanks. That's where I'll start--probably be next weekend job--I'll let you know. BI
