Aftermarket Lighting
Old Oct 23, 2002 | 11:59 PM
HuskerF150's Avatar
I'm wondering if anyone has had any luck with any "high output" aftermarket lighting bulbs...........reverse..........brakes etc.
Old Oct 24, 2002 | 07:22 AM
AB's Avatar
AB
Hi,
1. I put 9007 Showoff purple 100/80W on the truck. I don't think that they have higher output. Other than that they're OK, don't burn the harness . Installed fog lamps - they help a lot!
I heard positive responses on Eurolite 65/55W bulbs (eBay $20). They are stock wattage but 50% more output.
2. I have 55W reverse - I don't think they have higher output At least it's not enough for me... I guess you read the thread on how to install additional reverse lights, right?
3. Have not thought about brakes – don't want to scare people behind me
Hope that helps,
Alex.
Old Oct 24, 2002 | 11:27 AM
2stroked's Avatar
I've added 80/100 watt Krypton Quartz light blue headlight bulbs (from Competition Specialties) with the heavy duty wiring harness to my F-150 and the results were pretty good. Adding a set of Hella 550 Driving lights behind the grill with 130 watt bulbs in them REALLY made a difference. (They're wired with a relay to come on with the high beams.) I'm still looking for higher output bulbs for the fog lamps.
As for backup lights, I added a single Hella 550 mid-beam under the bumper with a relay. It did a heck of a lot more good than the (supposedly) 55 watt replacement bulbs for the factory back up lights.
Hope that helps.
Old Oct 24, 2002 | 12:51 PM
AB's Avatar
AB
2stroked,
Where did you get the heavy harness from? How much?
Is it for headlights only or you've replaced everything under the hood?
I heard that higher wattage bulbs could melt the harness so I want that heavy-duty thing...
Thanks in advance,
Alex.
Old Oct 24, 2002 | 10:51 PM
scubasteve's Avatar
fogs?
is anyone using the Eurolite H3 or 9006 for fogs?
_____________________________________
1999 F150 XLT super cab OFFROAD package 4x4
5.4 L Triton V8, automatic
Mods:
AutoPage RS-750lcd alarm/remote start
Dual stage proximity sensor
Ford Racing Euro tails
Xenon headlights
Spray on underbody coat
20% window tint on front 2 windows
Straight pipes w/ dual stainless tips
Audio:
Eclipse 6 ½ point source coaxials SP8962
Eclipse CD8052 head unit
Eclipse 2-channel amp 3122
Eclipse 4-channel amp 36401
MTX Thunderform sub box
Image Dynamics IDQ8’s
Future modifications:
Xenarc HID light kit
Custom 10” box
Old Oct 24, 2002 | 10:55 PM
pgh_medic's Avatar
See gallery, i think it may have what you are looking for!
medic
Old Oct 29, 2002 | 07:12 AM
2stroked's Avatar
AB,
I got all of my bulbs and the Heavy Duty harness from a place called Competition Specialties. It's a little mail order joint that doesn't even have a web site as I recall. (Been a while since I last ordered.) Great service though!
As for the HD harness, it runs from your battery to the headlights and includes all wiring, 2 relays, fuse, etc. The reason you need it is - as you said - if you draw too much current (from high output bulbs) through small gage wiring, it can fry the stock harness. You might also note that you're not getting as much light out of the bulbs as you had planned. The harness takes about 30 minutes to install and I've had in it my '97, '99 and now my '02. As I recall, it was around 40 bucks and has been well worth the investment for me. You just have to see it when I nail the high beams!
Hope that helps!
Old Oct 29, 2002 | 08:04 AM
AB's Avatar
AB
Thanks!
2stroked,
Super! Thanks a lot!
I'll check it out!
Alex.
Old Oct 29, 2002 | 08:21 AM
AB's Avatar
AB
Lightbulb
2stroked,
Do you still have by any chance any contact info for the company???
I tried surfing the web and nothing specific...
Alex.
Old Oct 30, 2002 | 06:22 AM
2stroked's Avatar
AB,
I had to do some digging, but found the name and number of the place I got my bulbs and HD harness. It's called Competition Limited and the phone number is (734) 464-1458. It appears to be a mom & pop kind of operation, but they're very helpful. They do not appear to have a web site though. Good luck!
Old Oct 30, 2002 | 07:06 AM
AB's Avatar
AB
2stroked,
THANKS A LOT!
They are still in business and it's around one hour from me!
Alex.
Old Oct 30, 2002 | 07:15 AM
AB's Avatar
AB
just in case
2stroked,
I thought it might be of interest...
They do have a web site:
http://www.hioutputbulbs.com/compt.htm
Alex.
Old Oct 30, 2002 | 11:39 AM
2stroked's Avatar
AB,
Thanks for the information because I'm about to place an order for some bulbs for a friend with an F-350. The web site must be a recent development. I'd highly recommend the Krypton Quartz HID Blue bulbs. IMHO, you can run the 70/80 watt bulbs with your stock harness. Going to the 80/100 watt beauties definitely requires the harness. I'd also recommend skipping the 55 watt backup bulbs. They sound good, but they're useless.
Here's another hint. Install your first headlight bulb with your truck about 20 feet away from a clean, flat surface. Check the aiming with one new and one OEM bulb in place. Sometimes the aftermarket bulbs have a slightly different filament position which you may have to compensate for by re-aiming. Once you've verified proper aiming, install the second bulb and check that too.
Enjoy!
