1995 - dashboard light
Old Oct 16, 2002 | 01:49 PM
jkp64's Avatar
Unhappy 1995 - dashboard light
Am the newly minted owner of a not so new but great '95 F-150. No Owner's Manual. Recently the dashboard lights went out (either that or I did something to switch them off) and i miss that deep phosphorescent green. How do I fix this, where do I find the bulb, etc. The warning lights work, but not the rest of the dashboard.
Thanks in advance.
Old Oct 16, 2002 | 02:15 PM
Rockpick's Avatar
Moderator &
It's not that the dimmer switch is turned all the way off is it? The dimmer should be your headlight ****... try turning it with your lights on to make sure that you didn't turn it off. This is also how you turn on the interior light.
Just a thought...
RP
Old Oct 17, 2002 | 10:01 AM
jkp64's Avatar
no, i checked that several times. i replaced the fuse but that didn't work either.
