connectors what are they for
I have noticed two connectors on my 99 ford supercab 2/wd. one is located by the brake pedal, the other is just to the right and under bottom of dash. Im not talking about the connector for the computer code scan.
popeye65,
One for sure is the Trailer Brake Wiring harness. Even if you only have the 4 wire flat pigtail on the back, all trucks have the connector wired in. If you have the tow package from factory and the 7 terminal plug,your all set. Just add Brake controller.
Not sure about that grey one I think there was only like 3-4 pins?
