hardwiring neon shift knob
Old Sep 8, 2002 | 08:15 PM
WHITE4.2F150's Avatar
hardwiring neon shift ****
i already have my STREET GLOW OPTX handle installed..but im tired of pluggin it into my power port......so i have a switch in my truck now...but im havin problem gettin power to it....this is how i have it installed...
switch -> ground=ground wire of the ****
Acc= power of the ****
Power=????
i tried drawing power from my fuse box...but it wont work...do i need to tie it to my battery???
or is there an easier way to get 12volts??? ..this is all i need to finish
Old Sep 9, 2002 | 08:30 AM
PumperMike's Avatar
Post 12 Volt Power Tap
If you want the neon on only with the park or headlights you can tap the Light Blue / Red wire in the main harness under the dashboard ( near the fushblock ) and use that for power. This is the instrument illumination power wire. Be very careful uncovering the harness and tape it back up again when finished. If you want the neon on while the key is in RUN or ACC you can use a Black / Pink wire from the same area ( check to see what circuit the wire is from ).
How much current does this neon draw? Do they say to use a relay? If so, install a relay with one of the coil terminals connected to one of the above wires and the other coil terminal connected to ground. Get power from the power point wiring behind the dash, Violet / Orange wire, this wire is hot at all times.
DISCLAIMER: As always you do this at your own risk. This information is provided as a suggestion only.
One good thing to have is a wiring diagram. You can get complete shop manuals with wiring diagrams on CD-ROM for around $15 on EBAY.
LOL
Michael
