Dash lights out!
Old Jul 27, 2002 | 11:24 PM
KnightS's Avatar
Suspended User
Question Dash lights out!
About a week ago my instrument lights didn't come on. Turned them on/off a few times and they came on. Worked okay for a few days then the same problem. Now they won't come on at all. I hit the dash a few times and reached under and wiggled some wires around but no lights. Checked the fuses-all okay. Lights around the a/c controls work fine. Same or different circuit? Any ideas where to go with this?
Old Jul 27, 2002 | 11:28 PM
gcblackbolt99's Avatar
I had the same thing happen to me on my 99L. I didn't know what it was that killed the lights in the dash cluster and everything I did to try to make them come back on didn't work. It ended up being the dash cluster itself that became defective. I had it replaced under warranty. BTW, it's not just a light bulb back there that lights everything up, the whole cluster's gotta go and be replaced. Hope the info helps.
Old Jul 28, 2002 | 08:35 AM
kidtriton's Avatar
That electroluminescent stuff is just used in the lightning cluster, his cluster does have bulbs that can be replaced.
Old Aug 3, 2002 | 04:04 PM
KnightS's Avatar
Suspended User
If there are separate bulbs, what are the chances of them all going out at once? Seems weird. If it's the whole cluster, now would be a good time for an upgrade to white faced ones I guess. The wife can't say "no" now!
Old Aug 9, 2002 | 12:48 AM
spaceman12321's Avatar
My '89 did that and it was the dimmer/headlight switch. Might be different for the later models, but isn't it the same concept?
Old Sep 12, 2002 | 01:43 PM
Quicker1's Avatar
I had the same thing happen on my 99 Lighnting. They want $728 to replace the dash cluster. Not covered by warranty apparently. Any other options to this huge repair bill?
Help! Thanks, Dan
Old Sep 13, 2002 | 10:36 AM
Quicker1's Avatar
The dealer is helping me out on this! New dash cluster needed for Lightning since it is electroluminescent panel not light bulbs...
