intermittant odometer
Old Jun 27, 2002 | 07:17 AM
Jimmer's Avatar
Hi folks I have a recent problem,
My odometer has become intermittant sometimes working sometimes not working. I am assuming it is a bad connection or cold soilder joint, the other gauges work fine..
How does one remove the cluster to check it out...
JIm
Old Jun 27, 2002 | 01:06 PM
bvbsktbll's Avatar
Here's an old post, hope it helps.
https://www.f150online.com/forums/sh...threadid=68492
Old Jul 8, 2002 | 10:58 AM
ugly_dog1's Avatar
Question Odometer Problem
Jimmer, did you fix your intermittent odometer problem? I am experiencing the same thing right now. Was it dust? Give me a shout.
Old Jul 9, 2002 | 05:57 PM
kidtriton's Avatar
I see that a lot, its just a intermittant flourescent display, you have to get a new cluster to fix it.
Old Jul 9, 2002 | 11:03 PM
hmustang's Avatar
Take about something I was going to post. I just started to have this problem myself sometimes after I start the truck it will be blacked out for a few minutes then just come on and other times it works just fine the truck almost has 55,000 miles on it and just started doing this the last couple of days. I thought it may be due to the heat we been having causing the computer to act up and cause the odometer to be blank for a little bit. But if it keeps up I'll have it checked out. As I like to keep track of my miles for oil changes and such.
Old Jul 10, 2002 | 07:32 AM
kidtriton's Avatar
Even when the display is out, the miles are still added. Its just like unplugging the monitor from your computer, its still runnin the same. I havent seen one yet to go out and never at least come on once in a while.
Old Jul 10, 2002 | 06:32 PM
hmustang's Avatar
I noticed the miles add up on it when its blacked out today.
Old Jul 25, 2002 | 11:33 PM
The Stranger's Avatar
add me to the list of owners with the Intermittent Odometer problem...
/adds it to the "list" for the shop...
Old Jul 27, 2002 | 01:18 PM
Jimmer's Avatar
No it is still intermittant, now it off more then on. Haven't gotten around to pulling the dask to see what I can see..
Anyone else have any luck?
Old Aug 2, 2002 | 05:54 PM
Mines in the shop still...surprise! the odometer is on back order and I might have to wait 4 weeks to get a new one...
Will keep you updated if a replacement fixes the problem...(it better)
Old Aug 17, 2002 | 11:42 AM
Still waiting on the replacement parts (Odometer)...which are back-ordered.
They replaced my swich for the power windows - fixed
They replaced my Turn signal assembly - "ghost wiper" problem fixed
They replaced door lock actuators both sides- locks now functional electronically-not just manually - Fixed
They replaced driver's side seat belt assembly- retractor spring weak, and is STILL on the weak side... Fixed, but not entirely satisfactorily.
Old Aug 17, 2002 | 06:43 PM
hmustang's Avatar
How much would it cost for a new cluster to fix the odometer.
Old Aug 18, 2002 | 01:03 AM
That price is probably online somewhere...but I will ask them when I go back in....
Old Aug 26, 2002 | 06:45 PM
4.6Reg cab XLT's Avatar
I also been having this problem whats the fix other than replacing the cluster.
Old Sep 5, 2002 | 04:54 PM
Don't believe there is a fix...other than replacing the entire cluster.
