Fog Light Switch Set-ups
Old May 17, 2002 | 07:57 PM
TimT's Avatar
Question Fog Light Switch Set-ups
Hello all...I recently purchased a second set of lights to add to my grill guard. I currently have a set of Hella 550 which are street legal and added a set of Procomp off-road lights to enhance my off road adventures. I also want to add a reverse light for hooking up to the boat trailer at night. I could just wire up a few switches but was wondering how other people set up their switches (location, lightes, mounting, etcs.) to give a real clean look.
Old May 21, 2002 | 04:14 PM
sjacobi54's Avatar
New to this site -
Read your question on fog light(s) and mounting - fog light mounting points (99' and up) are on the bumper directly below the head lights - these are behind the air dam - which unfortunately requires you to cut out the air dam for the lights to pass thru - I recently installed a pair of PIAA 510's (4in dia) - I used a 4.5 in hole saw (rent or borrow) to cut through the air dam and used the mounting points on the bumper. Dont' worry about being off a little bit (1/8-1/4") up/dwn/lft/rgt because the mounting hole is approx 9/16 and the mounting bolt shafts for the PIAA's are 7/16, and you can always shim up and down to get the exact fit. I'm using the existing lighting switch (pull back when lights are on) so that it works as a "factory fog install".
