Headlight Switch
Old Mar 16, 2002 | 06:20 PM
cesar58's Avatar
Question Headlight Switch
How do I remove the headlight switch on my 98 F-150XLT withoout breaking any of the studs. Thanks For your help.
Old Mar 16, 2002 | 07:53 PM
Dogface's Avatar
From Interior Care Forum
Here's a quick little headlight switch removal how-to. Turn on the headlights, and pull out on the ****. It should pop out about an eighth of an inch or so. On the bottom part of the **** (180 degrees from the pointer), there is a tiny slot. Stick an equally tiny screwdriver into the slot and pry the **** off. Turn the **** 180 degrees, and push it back on. Turn the headlights to the off position, and the switch should pop out. It takes a little wiggling, but it will come out. PLEASE do not pry the headlight switch out, or you'll be painting or replacing something you weren't planning to,,,,98
You can Thank 98SCREAMER
Dog
