Air Bag Switch Question
I have a 2001 F-150 SuperCrew. Is there any way to install a passenger-side air-bag switch onto this model of truck. It does not come as an option from the factory, but I am wondering if Ford would be using the same wiring harness, and all I need to do is plug in the switch? If I'm right and it's the same wire harness, could someone tell me where the switch would plug into the truck's wiring?
I'm not sure Ford would use the same wiring harness for the 4 door trucks as they do for the 2 door, too much liability if someone were to disable the airbag that easily. Could you just hear the lawyers?
People of the Jury, my client with help of FORD MOTOR COMPANY disabled the airbag VERY, VERY easily. If Ford did not make it SO easy for my Client His loved one would still be alive today.
'Loose said it perfectly. Technically, there should be no reason why you couldn't put in a factory kill switch from another F-series. However, try finding any mechanic that will install or remove an airbag. Huge liability.
