Overdrive off light
Old Oct 26, 2001 | 09:57 AM
leemcc's Avatar
Exclamation Overdrive off light
Last week my service engine soon light came on.This morning on my way to work the overdrive off light starting flashing on and off continuously...What does this mean, and how bad is it?
I have a 99 F-150 4.6 V-8 with about 78,000 miles...
Thanks for your input!!!!!!
Old Oct 26, 2001 | 10:20 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Ok, I'm quoting from the 1999 F150 Owners Manual pg.10,
"The TCIL (transmission control indicator light) may flash steadily if a malfunction is detected. If the TCIL is flashing, contact your Ford dealer as soon as possible. If this condition persists, damage to the transmission could occur."
Could be a sensor, about $60 for the part and $70 labor.
Ignored, it could lead to more expensive problems.
Old Oct 27, 2001 | 04:49 PM
Old Timer's Avatar
Question
Hi Lee
You didnt say, but what was going on prior to the warning lights coming on????
Raoul was right on about the TCL.
If you havent done it, gonna have to plug into the diagnostic port under dash. Chances are a code has been thrown. If so, then thats the starting point. That code = what may be wrong.
In my case, when the TCL started flashing, no other light came on. I noticed shortly before that, that my auto.tranny wasnt shifting right. Anyhow, ended up with a tranny rebuild under warranty and only 16000mi.
Mine was 99SC with 4.6L and 4R70W.
Ck. engine light in the past was more for the emission system. But on these newer models, the computer is reading alot of stuff feed into it. Makes it easier to figure out whats wrong because of all the codes installed. Of course that depends on whos reading it and there understanding of what they read.
Good luck. Maybe you could let us know when you find out....
Ck. engine light and TCL both on at same time. 2 different problems or same one?
Good luck. OT
Old Oct 27, 2001 | 09:38 PM
leemcc's Avatar
I'm going too find out whats wrong this week..
I'll let you know whats wrong...
Thanks again with your help...Was hoping it wasnt serious
but seems like it will be.Feels like im driving with my overdrive off although it says that it is on.....
Thanks....
Old Oct 27, 2001 | 09:55 PM
RebelYell's Avatar
Unhappy
Had the same thing last year. After 2! rebuilds already, the tranny had to be rebuilt yet again. (And rebuilt again and then replaced all together at my insistance the time after THAT! I quite honestly don't remember what the problem was the time when the OD light was flashing. I had so many probs with my 4R70W I can't remember them all.
Take it in, it needs something bad!
