Fog Lights
Old Apr 21, 2021 | 09:41 AM
Jim Robinett's Avatar
Fog Lights
I willing to spend around 300 dollars on my 2002 Ford F150 XLT Crew Cab before I do is it pre-wired I know the break Switch is for pulling a trailer
Old Apr 21, 2021 | 09:49 AM
Wink Fog Lights
On my Ford F150, XLT Super Cab 4.6L is it pre-wired for fog lights? I willing to spend good money to get the fog lights and put tow bars on the frame with a new Texture Front lower Valance with the new Fog Lights Tow bar hooks I have already brought the Factory Oem Switch to operate the new Fog lights
Old Apr 22, 2021 | 05:14 PM
Fifty150's Avatar
Even if it's not pre-wired, that's okay. You could install a relay, and trigger it with that OEM switch you bought. My truck did not come with OEM fog lights. I installed the bumper, and lights. I didn't even think about looking for factory fog harness. That's just another rabbit hole. Even if you found the wire and harness, who knows if it's even connected to the power supply. Are you really going to try to trace that wiring back to see if everything else is hooked up? What about the OEM relay for the fog lights? Then when you take your dash apart to swap out the switches, is there a harness there that will connect the switch to the relay? It was just simply easier for me to install a toggle switch, and run the wiring.
Old Apr 23, 2021 | 02:15 PM
jackmillerjr's Avatar
My 2001 F150 Lariat is wired at the switch connector in the cab; however, the main panel under the hood does not have the connectors for the relay or the wires to the fog lights. I suspect you will find the a similar situation.
If you find a way to add the relay and wiring under hood please post how you accomplished task!
