Power windows wiring workaround
Old Apr 7, 2020 | 12:07 PM
Shawn O's Avatar
.is there a way to bypass the fuse box and just run a wire direct from the battery to the power windows wiring harness?
Old Apr 7, 2020 | 02:02 PM
On what? We can't see your vehicle through the Internet.
Old Apr 7, 2020 | 04:57 PM
Shawn O's Avatar
My bad. 2001 f150 supercab 4.6l 4x4. Thanks.
Old Apr 8, 2020 | 06:39 AM
projectSHO89's Avatar
Can you? Yes, if you know what you're doing.
The better question is "WHY?" as in what problem are you trying to avoid fixing properly?
Old Apr 8, 2020 | 09:27 AM
Shawn O's Avatar
​​​Have a big electrical problem. Swapped out the gem module, which didn't fix it. Going to replace the fuse box next. If it doesn't work I want to bypass it. I need my windows to work. Not to mention my turn signal. Huge fuster cluck.
Old Apr 10, 2020 | 06:16 PM
Shawn O's Avatar
For some reason my reply was censored.
As a last resort. If replacing the gem module and fuse box don't work, I need my windows.
Old Apr 10, 2020 | 06:37 PM
Let us know if you get to that point.
Old Apr 12, 2020 | 02:15 PM
Shawn O's Avatar
I'm stuck at this point.
Ok. It's not the fuse box or the gem module. Do you know how to bypass? Need my windows. This truck has to last the summer before I can replace it.
Old Apr 12, 2020 | 03:04 PM
You can run fresh wiring from the battery (make sure it's fused), to the door, and attach it to the window switches and motor. It's a fairly simple process.
If you can't do it, I highly suggest finding someone that is competent in electrical wiring.
Just please... make sure it's fused with at least 5-10 amp fuse.
Old Apr 12, 2020 | 03:26 PM
Are you positive it's not just a bad driver's door switch cluster? Have you tried troubleshooting with a multimeter to see where the voltage is lost?
Old Apr 12, 2020 | 05:53 PM
Shawn O's Avatar
Thank you very much. I'll give it a shot.
Old Apr 12, 2020 | 06:18 PM
Shawn O's Avatar
Old Apr 13, 2020 | 04:44 PM
Shawn O's Avatar
It loses power upstream of the relays, in a different circuit that keeps blowing fuses (either dome lights or battery saver). The power windows circuit is dependent on the other circuit having power.
Old Apr 13, 2020 | 04:50 PM
You might want to try to find and fix that short before you hack into the window wiring.
