charging system
Old Dec 2, 2018 | 12:13 PM
Jeff North's Avatar
charging system
i have a 2001 ford F150 with a 4.6.
Around a month ago it would not start so i changed the tested and not so good battery, It worked fine for a few days and same thing, discovered i had a parasitic drain through the alternator so i replaced it. Again after working fine or a couple days now its over charging, +18V , My next step is to remove and have alternator checked or is there something else I should be looking at?
Old Dec 2, 2018 | 04:28 PM
I would recommend getting your alternator tested.
I've had bad luck with alternators lately.
Old Dec 2, 2018 | 04:39 PM
Check all your grounds.
