wipers out/ bad GEM module
Old Sep 28, 2018 | 03:46 PM
Craig Harrison's Avatar
hi. I have an 03 F150 Supercab FX4 with a 5.4. Its great & I love it. 250,000 miles. almost 110,000 of them with me and its been basically faultless. Until now The wipers stopped working recently and the diagnosis was bad GEM / BCU module. This thing is obsolete / unavailable new. I went through a couple of used ones and none really fixed the problem - one did, but the headlights stopped. The others didn't fix the wipers . Right now, I have the wipers working off a standalone switch. Whilst it keeps the water off the screen, its a little inconvenient / clunky and intermittent/ 2 speed/ self park etc aren't working. I was wondering about getting a wiper control module from something else - either a different Ford model, or something entirely different and hooking that up to the multifunction switch - I'm thinking that of the 2 connectors that plug into the multifunction switch, one of them is lights/ blinkers etc, and the other is going to be the wipers/ 2 speeds and multiple intermittent speeds (and washers - which still work) - from what I see online, the funny shape one is the lights - and the square one is the wipers (and washers?). so I'm thinking totally bypass the existing GEM for the wipers and reroute the wiper wires headed into and our of the GEM module into the new wiper control module, and route that thing directly to the existing, or perhaps some custom relays
So anyway - my question. Has anyone else done this? if so - what module did you use ? Any trouble/ anything specific to watch for? I assume this ought to work reasonably well - only immediately problematic thing I see is previously turning the washers on activates the wipers, and now 2 different modules need to communicate to do that. I could feasibly take a 12V feed directly from the washer motor though and run that as an input into the new wiper control module.
Thanks in advance for any help/ advice.
Old Sep 28, 2018 | 05:06 PM
Get a remanufactured GEM.
https://www.rockauto.com/en/catalog/...ule+(bcm),2888
Old Sep 29, 2018 | 02:32 PM
Thank you!! I would have said I looked everywhere for one of those unsuccessfully. That’s a much better solution and is exactly what I’ll do!
Old Sep 29, 2018 | 05:15 PM
Hopefully you have an electronic shift transfer case, the one for the manual shift costs a LOT more.
Old Sep 30, 2018 | 07:15 PM
yeah. Esof. Thanks again. It’s on order. Excited to have wipers that work properly again 😊
Old Oct 1, 2018 | 12:20 PM
Good deal! Let us know how you fare when you install it. We always like to hear good stuff.
