Passenger window doesn’t go down
Old Feb 8, 2018 | 06:20 PM
5.4rico's Avatar
Hi, I’m kinda new to this forum so I didn’t really know where to post this problem I’m having that I can’t figure out. So the thing is that my passenger window doesn’t go down. Neither with the passenger button or the driver one. Now I put power directly to the passenger window and it went up and down and it stayed working on its own power from both switches for 2 days. But then after that it stopped working again. Some people told me it could be the master switch but some people tell me if it went up and down that it can’t be that. I have no idea what to think anymore. It is a 99 f150
Old Feb 9, 2018 | 06:48 PM
I would check the GEM for corrosion and the windshield for leaks.
The GEM is on the passenger side foot well.
Old Feb 9, 2018 | 06:55 PM
5.4rico's Avatar
ill check but my drivers window works along with everything else it’s just the passenger window...oh and the drivers side power lock doesn’t work only the passenger power lock works
Old Feb 9, 2018 | 06:56 PM
It can't hurt.
Only other thing it might be is a loose connection.
You can get a voltmeter and ohm everything out.
Old Feb 9, 2018 | 11:53 PM
No the GEM is behind the fuse box under the driver's side of the dash on a 99.
