Location of 2012 Ford F-150 turn flasher relay
Old Jan 28, 2018 | 03:05 PM
Uncle Craig's Avatar
I purchased a turn signal flasher relay from O'Reilly Auto parts but they cannot tell me where to find it on the truck. I have found were some people say there isn't one? Need to find the location
Old Jan 28, 2018 | 03:57 PM
There is no serviceable flasher -- No flasher for the 09 and up f-150's. The bulb flash time (80 per minute) is controlled by the BCM. When it detects a bulb out (or a low resistance LED) it flashes 160 times a minute. The sound you hear is created by the cluster to mimic the sound of a conventional flasher. If you search the forum, or someone may chime in, there are resistors you can get to add to the turn signal circuits to slow down the flashing.
Old Jan 28, 2018 | 04:19 PM
ManualF150 That is even more disturbing as the auto parts store sold me the part and swears it will fit the truck however they cannot tell me where to put it. My problem is the passenger side rear blinker will not work. I have replaced the bulbs. When you turn on the blinker it flashes fast on the right front and right mirror. When you turn the left blinker it blinks normal. Any ideas?
Uncle Craig
Old Jan 28, 2018 | 05:09 PM
The people behind the counter will sell you everything in the store, just because they can, they usually have no technical knowledge for these new vehicles. If they did, trust me, they wouldn't be working at O'Reillys....
It sounds as if there is an issue with the wiring. I would double-check all connections and bulb sockets.
If not, the next best thing to do is return the part, and go to your local Ford dealer so they can run some diagnostics.
Old Jan 28, 2018 | 05:22 PM
Thanks.
Old Jan 29, 2018 | 12:32 PM
Check this thread out:
https://www.f150online.com/forums/il...rt-ground.html
The smart junction box has failed and needed to be replaced. There was no short in the electrical system otherwise.
Might be relevant to your issue...
Good luck.
Old Jan 29, 2018 | 10:33 PM
Good luck.
Thanks! I will look into it.
