Left rear Blinker and Brake Light
My left rear blinker and brake light quit working at the same time. I have changed bulbs and this did not fix the problem. Open for suggestions. The truck is a 1999 XLT F-150 Extended cab
We need to know what year and model truck you have, but it sounds like the ground on that side is defective. Does your park light still work on that side?
Left rear tail light
My left rear tail and blinker have also stopped working. I have 1997 F-150 XLT 4X4. I have changed the bulb and check applicable fuses, both were fine. I am not sure how to check the "ground" for the light. If someone could point me in the right direction I would appreciate it.
Left park light
The left park light is all that is out. The blinkers and brake lights all work. Only the park light fails to come on. All other lights work correctly. I have checked all the fuses and all the wire that I can find/see. If anyone has any ideas how make my light work please share them.
