2009 F150 door ajar and window not closing
Old Feb 19, 2017 | 10:43 AM
moosensqrl's Avatar
I am having electrical issues with my 2009 F-150.
Initial problem (30 days ago)
When the driver door ajar alarm comes on, none of the windows are working and also locks will not operate from driver side.
Second issue (5 days ago)
Starting last week, my door ajar alarm came on and has not gone off since.
I was able to get the door ajar light off briefly after I closed the door repeatedly. That was the last time door ajar switch worked.
Today I sprayed lubricant into the door latch mechanism and worked the latch, no effect.
Anyone know the answer?
Andy Horti
Old Jan 8, 2018 | 07:45 AM
buddyguest's Avatar
Question Status?
Were you able to find a solution? My truck started doing the same thing.
Old Jan 14, 2018 | 11:31 PM
streetracer1232's Avatar
check the wires in the door jam the harness that runs from cab to door, may have a broken wire
Old Jan 16, 2018 | 12:07 PM
buddyguest's Avatar
Thank you, there was a broken wire in the harness.
