09 F150 charging system
I have a 09 F150 I just recently changed the alternator on it. The problem started when my "check charging system" light came on and all of my electronic components stop working dash light,radio etc. I made it home so the following morning I charged my battery and replaced the alternator.. I took it for a test run and all of sudden the Check charging system lights comes on again.. I took it to O'Reilly to let them check it out and the results came back "battery good " and alternator putting out 14 volts. Later that evening I drove it everything seems to be good but my headlights and interior lights have a small flicker when idling. I running out of ideas Can someone suggest some new ideas please.
Actually I went to alternator shop and they tested it on the truck and they told it was bad. They told me they didn't have the parts to rebuild it, so I purchased one from O'Reilly. O'Reilly did test my old one off the truck..
In the morning I will try clean my cables and look for any flaws in that area..
Thanks for your help
