04 F150 FX4 keyless entry code location?
Old Dec 18, 2016 | 09:54 PM
Santana-911's Avatar
Question 04 F150 FX4 keyless entry code location?
Just purchased a used 04 FX4. Didn't get the code to the drivers door. Where can I find it? Thx in advance
Old Dec 22, 2016 | 08:51 AM
SSCULLY's Avatar
Sorry somehow this got lost in the threads.
The BSM/VSM that the code is printed on is on the back cab wall behind the seat back.
You will need to remove the seat back to get to it.
This is the thread I used to pull my seat back when installing the LWI seat risers.
https://www.f150online.com/forums/20...08-my-way.html
Here are some placement pictures for where the screw driver releases the clips.
good luck, it will be a bit finicky the 1st time but after that is easy once you do it.
- I had mine out another time after this for the rear seat heaters and that time I zip tied the clips so it would just pull straight up after releasing the top of the seat.
