please help with hooking up additional rear cam
Old 12-08-2015, 07:13 PM
miran587's Avatar
hi i have a 2012 f150 harley davidson addition and i want to tap into factory harness behind radio for rear cam screen to add a camera for my trailer when backing up my trailer anyone with any input
Old 12-09-2015, 08:59 AM
I added a whole system with a screen in the rear view mirror. Camera in the tailgate handle
Old 12-09-2015, 10:33 PM
SSCULLY's Avatar
Are you trying to reused the factory camera feed ?
- Is there one already installed ?
Just want to clarify what you are trying to do here.
Old 12-10-2015, 06:59 PM
If you are trying to do 2 feeds from 1 wire -- this is impossible.
You will need to run another cable to the rear.
Old 12-11-2015, 07:40 PM
miran587's Avatar
yes im trying to have 2 feeds one from stock tailgate then another one when my trailer is hooked up i can have one mounted to trailer i under stand cant have 2 signals coming in so i was going add a switch for when i want to use trailer
Old 12-12-2015, 01:03 AM
SSCULLY's Avatar
My question was a bit vague.
I was talking about the the factory camera wiring, but I think I am clear now that you are trying to reuse the camera display in the factory head unit, and rerun a new wire for the trailer camera.
The Color codes at the Front Display Interface module ( FDIM ) are :
REar Camera video + = White w/ Green Stripe wire.
REar Camera video - = Brown w/ violet stripe wire.
Shield wire is Black It should be right at the back of the FDIM
I do not know what the video levels are on the + & - rear camera video feed, so you will need to test this with an external display to make sure it is not too "hot" a video feed for the FDIM.
- I think it is pretty much standard, but this is jsut a SWAG, I cannot say one way or the other 100% certain.
Quick Reply: please help with hooking up additional rear cam
